Replace a 2.7 Engine?
Long story short: 78 911 Targa needing replacement of a oil leaking 2.7 engine.
Needs seat skins and some elbow grease but overall not too bad. Price asked is $8000 but I can get it for less. Questions: 1. A worthy undertaking for my first 911 project? 2. Realistic price? 3. Worth buying and driving with leaky 2.7 while saving $5000 for engine swap? Thanks - Dickson |
ROW '78 911 Targa
Who put a 2.7 in a '78?
Should be a 3.0 |
Under the radar
Welcome and good luck with your project. However...
I'm sure you will get a lot of support here but you are going to need to give more details about the car. Pictures will help. Especially of the motor. BTW 1978 911s have a 3.0 motor, not a 2.7.
Yes, confirm that it is a 2.7 and not a 3.0.
As for oil leaks, why not try to hunt them down and resolve them rather than replacing the engine?
1976 911S; 1957 Mercedes 190SL; 1982 Ferrari Mondial Coupe; 1991 Nissan Figaro; 2001 Panoz Esperante ; 1969 Pitts S1C http://forums.pelicanparts.com/porsche-911-technical-forum/664950-1976-911s-garage-find-road.html |
Crusty Conservative
Engine choices
You can upgrade to an EFI 3.2 Motronic for that kind of money. Then you have more fun, on less fuel...
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
Yes, I'm aware that it should be a 3.0....Not sure why the 2.7 swap.
I've decided that this is a project better left to someone else. I'm holding out until I can buy a much better candidate. THANKS |
Air Medal or two
what makes you believe it is a 2.7 ?
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
My previous 78 SC also had a 2.7...and ran like hell.
Well, it was a 2.7RS
![]() 911 C2 Turbo Look ![]() Harley Fat Boy ![]() Jeep TJ Sporttrac Adrenalin![]() 911 SC(sold) Sporttrac(sold)
Taking it apart is easy
Good call. My 2.7 runs fine, has no leaks, etc., but if you are not comfortable with a swap (if needed!) then get another car.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
