Help...
While I was changing my fuel sending unit in the tank the metal cylinder that the float is housed in fell into the tank. Any advice on how to retreive it?
Old 09-13-2012, 07:23 AM
ROW '78 911 Targa
timmy2's Avatar
Can you see it in the tank?
Get a set of retractable grippers or use a coat hook to get it out.
Remove the gasket to get a little more room.
Old 09-13-2012, 07:26 AM
Local Mad Scientist
Andy911sc's Avatar
two fingers worked for me. mine luckily was still standing straight up by the hole. I put my two fingers down the center of the tube, spread them apart like a reverse pliers and slowly brought it back up out, until I could grab it with my other hand.
1982 Porsche 911sc
2009 Jeep Grand Cherokee Laredo X
CPA-PCA Member Since 2012
Old 09-13-2012, 07:27 AM
No cant see it it fell down and is laying on the bottom in the front
Old 09-13-2012, 07:33 AM
'73 911 T Targa
I just pulled my sender to have a look at the tank and found a piece of metal in there that I retrieved with a coat hanger. I wish I'd had one of those claw retrieval picker upper things that has a plunger on one and and prongs that pick stuff up on the other end.
It was a lot easier to see in there with the tank empty.
Amazon.com: Flexible Claw Pick Up Tool Automotive Mechanic Shop 24": Home & Kitchen
Old 09-13-2012, 07:36 AM
PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
Cool
+1 Clumsy hands here... so I have one of those, very long nose pliers, mirrors with extended arm, magnets with extended arms, you name it... only thing I am missing and hope to get soon, is one of the thing cameras that can go into a sparkplug hole to inspect and take photos...
Back to topic, get that flexible claw, it will come handy in the future as well.
And whatever you do, use a flashlight, not a match, to look in the tank... and avoid smoking while doing this task
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 09-13-2012, 07:54 AM
Got it thanks for all the suggestions
Old 09-13-2012, 08:12 AM
