rallen911's Avatar
Fuse Panel Wiring Question
I am trying to remove what's left of my Ungo security system, and I have a question regarding removal of wires from the fuse panel.
It looks like all of the wires going into the Ungo harness are wired to the top terminal of the fuse panel. It seems like the top terminal is the "destination" and not the "source" of the power. Is that a correct statement?
I am hoping that I can remove the wires for the security system without affecting the other existing wiring.
Thanks for the help!
- Rob
'86 911 Carrera Coupe
Old 08-16-2014, 07:21 PM
photos?
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 08-16-2014, 07:53 PM
fred cook's Avatar
Fuse Panel.........
The top of the fuse panel is (for the most part) where the circuits come in with the bottom being where the fused circuits go out to the device being fed power. There are, however, some circuits that come to the top of the fuse panel that are not fused but simply come to get power, etc. It would be good for you to find a copy of the wiring schematic for your car to help you understand what each wire does and if it is still in it's correct position. Good luck with your project!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 08-17-2014, 04:32 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Fuse panel.
Hope this helps.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-17-2014, 07:03 AM
rallen911's Avatar
Here is what it looks like now...
This is a continuation of this thread Another Ungo Removal Thread, though I didn't know it when I started it.
Here is a photo of what is going on:
Just in case the notations are too hard to read on the photo:
1 - Looks like an extra relay
1a - purple wire from relay to panel 1-1 (clock, glove compartment light, interior lights, luggage compartment light, radio)
1b - red/brn wire from relay to panel 1-3 (fuel pump)
1c - other red/brn wire from relay through barrel crimp to what looks like a factory harness going down past the fuel tank.
2 - wht/grn wire from Ungo harness, looks like it should have been connected to the relay (2 open blades on relay)
3a - wht/red wire from Ungo harness to fuse end disconnected
3b - wht/red wire with matching fuse connector to 3a connected to 3-3 ( convertible top, head lamp washer)
4 - wht/prpl wire from Ungo harness to 1-7 ( heated washer nozzle, rear wiper, windshield wiper switch, wiper delay relay)
5 - wht/gry wire from Ungo harness to 2-1 ( high beam left, high beam indicator)
Now that I see the connection to 1-3 (fuel pump), I'm starting to think it may be related to another problem I have been having!
- Rob
Old 08-17-2014, 10:07 AM
'86 fuse panel.
Our '86 Fuse panel.
Good luck,
Gerry
1986 911 Targa.
Only in L.A.:
Old 08-17-2014, 10:12 AM
Tags
fuse , panel , security system , wiring
