1984 911 modification increase HP
Hi I want to know what modification I can make to my 911 targa 1984 3.2l to max the hp,
from the stock to the top... if is possible with out open the engine... I already have a comp chip about 15hp, 2.5 cat-back with headers what headers have installed I don't know, and a K&N air filter... I don't know how much HP all that part bring to the engine... any recommendation???? |
Craig T Volvo V60 - Daily Driver (I love it!) 997 Turbo - FVD Exhaust, GIAC Tune - 542 dyno hp on 93 oct 1972 Chevy K-10 Pick-Up Truck Hugger Orange
I think you are about there without internal engine mods. Regearing the trans would help the car seem quicker, but would cost some money. Losing some weight wouldn't hurt either.
I also would like to hear some input on your question. Dean
2017 Toyota Tacoma TRD Sport(Hate it) 1965 Chevy Biscayne Last edited by 911dean; 09-17-2012 at 07:39 PM.. Reason: spelling |
Senior Advisor
weight/hp ratio is the cheapest way to go, you did just about the most you can do with the engine. Go back to a OEM paper filter, the K&N does not add enough hp to counter the wear to the engine. You can loose about 500 lb but it will look like a race car, if that's ok. Or add a 3.6
08 Cayenne Turbo |
Turbo, then add a supercharger to DOUBLE BLOW it!
Gary R. |
to max the hp - from the stock to the top... if is possible with out open the engine
options: remove weight - go on diet - learn to drive - trade for viper what on earth would you want more HP for....are you drag racing? what are your lap times at what track...we actually CAN help you
Ed M 86' Coupe |
What are the 0-60 times (compared to stock) for an engine with the usual upgrades? eg chip, bypass, sports exhaust etc?
Ed. |
Rescuer of old cars
I'm with Ed on this. My '84 with just the chip and pre-muffler has more power than is needed for public streets, and I'm not yet good enough to need more power for auto-x or the track. I've got much learning yet to do.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
love the new avatar pic Arne!!
Ed M 86' Coupe |
Buy a 1999 Ford Mustag GT with 260 HP with a 5 speed stick.
Senior Advisor
good point, this is a porsche, and a classic porsche, hp doesn't fix everything, late braking and turning wins races.
08 Cayenne Turbo |
for your enjoyment - a buddy of mine and his 216 HP 72' T
HP is the last thing most people need Old Beater Sports Car at Pacific Raceways - YouTube
Ed M 86' Coupe Last edited by ivangene; 09-18-2012 at 05:34 AM.. |
get it tuned by someone who knows what there doing . theres a place in maryland that can dyno tune your car and get you about 15-20% more hp over what you have now . its called behe performance .
PMO's!
Chris '75 911s 3.2 - Ice Green Metallic ‘87 951, '05 987 S '21 Jeep Gladiator ‘18 Tesla ModelX 100D, ‘20 Model 3 |
If you haven't touched the air flow meter, now might be the time. Sometimes tightening up the spring tension on the clockspring in the AFM can wake up the beast. Just be sure to pencil in an index mark to know where you started.
Gosh Ed, that video was superb !! The guy had a great car control and his placement and gear changes were right on the money ....KUDOS !!
15 year PCA member ![]() 1972 911 E Coupe - gone now 1987 Mazda RX-7 2+2 - still cooking Swift DB-1 FF & Swift DB-3 F2000 -not forgotten 1979 911SC 3.0 & 2000 Camaro |
Porsche's Love-em Live-em
Turbo, then add a supercharger to DOUBLE BLOW it UP!
I'm with Ed on this. My '84 with just the chip and pre-muffler has more power than is needed for public streets, and I'm not yet good enough to need more power for auto-x or the track. I've got much learning yet to do. |
I don't know about everyone else, but I would like more power just for the fun of it. I don't race on the street, and I certainly don't drive to my cars limit at AX, but the thrill of acceleration is enough for me. If I could easily add power to my car I would. I'm guessing that is what hyperkinesis is looking for.
Bolt-on a turbo. Protomotive Stage 1 330-375 HP, the upgrade adds an intercooler for 425 HP Protomotive Turbo kit Information- what do you think?. Dunno if they're still available - but these were bolt-on kits. Except in my experience, it wouldn't be just the Upgrade package that would need an upgraded 915 clutch (a Sachs Power Clutch gets pretty marginal around 300 ft/lbs)...
You're boost-limited with the original SC/3.2 P&Cs, because effective compression goes into the stratosphere. For more power/boost still, replace P&C's with Nickies/J&Es, replace DME with a boost-aware system, ideally twin-plug. That should be good for around 550HP without getting extreme. At which point your problems will likely include suspension, brakes, fear and actually finding somewhere you can open it up
'77 S with '78 930 power and a few other things. Last edited by spuggy; 09-18-2012 at 11:10 AM.. Reason: added note about clutch. |
