Slight Vibration While Shifting
Lately, I have been noticing a slight vibration on the shifter when I shift from 2nd to 3rd gear. It almost sound as if the shifting mechanism needs lubrication (like a whirrrr sound). I will be removing the leather boot this weekend to check if it is a lubrication problem. My concern is that it may also be a vibration which starts at the tranny. Anyone has experienced this phenomena? If it is the transmission, could it be that the tranny is low on fluid. I have not changed the trans. fluid since I brought the car in 1999. I will also check the level this weekend, and plan to replace the fluid in the coming week. I assume that I should use the SWEPCO, which is what is recommended here on the board. Thanks in advance for any thoughts.
Ruben
1976 911s 2.7 L
Old 06-07-2002, 09:27 AM
Does the vibration occur only when you engage and disengage the clutch? Does it happen from a dead stop while pulling away in first? If so, it could be the clutch.
Eric
83SC
Eric
1983 SC
Old 06-07-2002, 09:53 AM
