tassie targa 76's Avatar
need help to id calipers
G'Day all
attached are pictures of my rear calipers
can someone tell me if they are correct for my 76 911s
1 appears to be dated 73 and the other 74 would this be likley
i want to put kits through them so need to correctly id them.
also the back of the rear calipers have number 26 on the one shown and number 30 on the other what does this mean
also the front calipers are alloy and have 4 pistons in each and purple in colour
i will post pics of these tomorrow but any ideas
project 1976 911 targa
everyday drive 1995 318i BMW
wifes car 2001 c200 kompressor coupe
spare 2006 mazda bravo ute
Old 09-24-2012, 02:42 AM
photo of front calipers
found some photos of the back of the front calipers
Old 09-24-2012, 03:00 AM
djpateman's Avatar
Not quite sure what the front calipers are, but they are not original to the car. They may be Boxster. They do appear to be 4 piston type, so much newer than the car.
The rears appear to be the correct vented M calipers for that year.
The numbers on the calipers are generally casting identifiers, not dates.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 09-24-2012, 07:10 AM
brembo
thanks for the info rear all sorted now even after struggling with 3 seized pistons
the front pictures are now attached and are clearly Brembo but from what
dont need any parts now but how do i know what to order in the future
are these standard porsche discs and what about pads
Old 09-25-2012, 03:16 AM
IROC's Avatar
I would have to guess that "986" indicates Boxster brakes...
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 09-25-2012, 04:17 AM
Thanks all brakes now sorted
yes they are boxter 97-04
only issue is which disc do i need to get in the future
boxter or 911 they are 24 mm
Old 09-25-2012, 06:51 PM
mfyoung1086's Avatar
If I recall this conversion right it is the normal 911 rotors, as the boxster rotors have a different offset, but I think a quick search on the forum should turn up a better answer than I can give off the top of my head, whats the rotor diameter?
____________________
1985 Carrera: Big Reds = Ass Saver
Old 09-25-2012, 07:04 PM
