-   -   A barn find, need some help. (http://forums.pelicanparts.com/porsche-911-technical-forum/708427-barn-find-need-some-help.html)
bassam 09-26-2012 01:56 PM
my friend found this car and was asking me if it's worth something. The owner is saying it's a 1966. Vin is 302317. Thank you.
http://forums.pelicanparts.com/uploa...1348692466.jpg
http://forums.pelicanparts.com/uploa...1348692487.jpg
http://forums.pelicanparts.com/uploa...1348692504.jpg
http://forums.pelicanparts.com/uploa...1348692690.jpg
http://forums.pelicanparts.com/uploa...1348692707.jpg
http://forums.pelicanparts.com/uploa...1348692966.jpg
Daves911L 09-26-2012 02:23 PM
Yup, its worth something. An interesting early car. Some weirdness with the fiberglass parts, but overall doesn't look messed with too badly. Everything depends on condition, which is impossible to tell from these photos. Motor looks like its from something else, MFI 2.2 maybe? That could also be interesting.
jamesnmlaw 09-26-2012 02:27 PM
1965
Red Book says it is a 1965, manufactured between January and July, 1965.
Do you know the engine number?
I don't know about value. If the engine matches then you've moved into the major leagues.
bassam 09-26-2012 02:30 PM
will see the car tomorrow, I will check the engine number as well. I'll post more pictures when I see the car in person. Any general idea on value if engine is matching?
Arne2 09-26-2012 03:45 PM
Depends on how extensive the rust is.
Dan J 09-26-2012 05:15 PM
I've owned more then 35 911's over the last 30 years, Know a little about them
I would run YMMV
RWebb 09-26-2012 06:10 PM
try to probe the usual suspect areas with a pick or small screwdriver
- post if you need help on where
creaturecat 09-26-2012 06:16 PM
I would run YMMV
Which direction, towards or away?
bavaria911 09-26-2012 08:23 PM
Don't say where the car is located... or you"ll have competition.
bassam 09-26-2012 08:45 PM
Again, I'm NOT buying the car, I'm trying to help my neighbor to make a decision. A $3000 one. looks like the car is a rust bucket with an aftermarket sunroof!!!
http://forums.pelicanparts.com/uploa...1348717424.jpg
GWN7 09-26-2012 09:40 PM
A 65 for $3K....yes it's worth it. As mentioned check the serial number of the engine. As there are other "upgrades" that have been done I'd suspect the engine might not be original.
bassam 09-27-2012 07:08 PM
new pics
I saw the car in person and took some pictures, the owner wants $7,500 has a Texas title. It has rust and poorly repaired rust. engine looks like a 2.7??? not sure. what do you think? Thanks.
http://forums.pelicanparts.com/uploa...1348797658.jpg
http://forums.pelicanparts.com/uploa...1348797674.jpg
http://forums.pelicanparts.com/uploa...1348797691.jpg
http://forums.pelicanparts.com/uploa...1348797711.jpg
http://forums.pelicanparts.com/uploa...1348797724.jpg
http://forums.pelicanparts.com/uploa...1348797742.jpg
http://forums.pelicanparts.com/uploa...1348797775.jpg
http://forums.pelicanparts.com/uploa...1348797796.jpg
http://forums.pelicanparts.com/uploa...1348797811.jpg
http://forums.pelicanparts.com/uploa...1348797830.jpg
bassam 09-27-2012 07:09 PM
http://forums.pelicanparts.com/uploa...1348798144.jpg
http://forums.pelicanparts.com/uploa...1348798162.jpg
bassam 09-27-2012 07:14 PM
http://forums.pelicanparts.com/uploa...1348798427.jpg
http://forums.pelicanparts.com/uploa...1348798451.jpg
cool5 09-27-2012 07:27 PM
Looks like it was originally slate gray, no aluminum trim around the the wood dash, engine appears to be mech injection, sounds like a deal at $7.500, but be ready to spend $$$$ to make it right.
bassam 09-27-2012 07:31 PM
it was originally light blue then yellow, black and what it is now.
TimT 09-27-2012 07:48 PM
Yes if you are insane....
I would run YMMV
If you are a parts swapper, hoarder, etc... you might get some money out of it..
RSTarga 09-27-2012 07:56 PM
3000 +70,000 and you've got the wrong engine.
PCA7GGR 09-27-2012 07:59 PM
How much just for the tools?
RWebb 09-27-2012 09:04 PM
did you probe underneath?
can the buyer weld? do his own body work? paint?
