LinkBack Thread Tools Rating: Thread Rating: 4 votes, 5.00 average.
Remove brake backing plates, front and rear = free.
Shifter bushing and coupler bushing = $20.
Remove bow tie on air system = free.
remover AC, spare tire, rear seat back = less 110 lbs.
Cool collar
Adjust air pressure in tires correctly = free
Dead pedal = $60
Gate shift kit = a little more at $150 put potentially worth about $5k.
Drivers trainer = priceless.
Old 06-08-2002, 03:11 PM
Send a message via ICQ to Kurt B Send a message via Yahoo to Kurt B
Neon windshield wiper jets.
A "Jim T if you have an aftermarket radio, you're rice" sticker.
-kb-
Old 06-08-2002, 05:58 PM
Send a message via AIM to 82SC
Pull the door buzzer
its free
also the 10 sec light delay when the door closes
awesome
MJ
Old 06-08-2002, 06:32 PM
jlui's Avatar
Removed metal bracket surrounding the ashtray to enlarge the openning. I don't smoke, but use the tray to put items in it. $0.00
Rotated tach, speedo dials $0.00
Jeff
1990 C4 modified
Old 06-08-2002, 07:18 PM
Doug E's Avatar
Registered as a member of the Pelican community ... FREE!
Doug
'81 SC Coupe
Old 06-08-2002, 08:02 PM
Chuck Moreland's Avatar
Let me see....
I've done plenty of cheap stuff. Here are some of the most satisfying:
Maintenance -
Pressure wash and degrease engine, underside and suspension - Free
Lubricate steering column u joints - Free
Rebuild calipers - $50
Shifter and coupler bushings - $75
Front control arm bushings - $70
Spring plates bushings - $50
Sway bar bushings - $50
Adjust clutch - Free
Adjust valves - $20
Pedal cluster bushings - $15
Anti seize on lug nuts - $3
Performance -
Smaller, lighter battery - $50
Delete rear seats, AC, cruise, heater fan - $15
5 point harness - $85
Lower - Free
Corner balance - Free
Remove tool kit, spare - Free
Keep tank half empty - Free
Drain windshield spritzer tank - Free
Roll fender lips - Free
Box in front oil cooler - $2
Chuck Moreland - elephantracing.com - vonnen.com
Old 06-08-2002, 08:28 PM
$13 today for an aluminium sheet to make a splitter.
Old 06-08-2002, 10:21 PM
bento's Avatar
thanks for all the great feedback guys. current ones that are on my mind include throwing away the a/c (but on my double black coupe i'm not entirely certain), rear seat backs coming off (roll bar blocks them anyway), aj usa dead pedal, shifter bushings for my g-50 w/ some mobil 1. i also need to address my door hinges which are not stopping the door at the 2/3s open position anymore. this thread also got me thinking about the pedal cluster; mine feels good, but it seems like something that you would appreciate when you refurbished it.
if ya got more, i'm all ears.
db
oversteer...there is no substitute
Old 06-09-2002, 02:58 AM
bento's Avatar
Bumpiddy Bump Bump.
come on, i like them so much, there's gotta be more.
db
Old 06-09-2002, 04:15 PM
Chin spoiler I found for $50.00 which was almost in new condition...
84 EuroCab
Old 06-09-2002, 04:18 PM
StanChung's Avatar
Best no or low cost things I've done so far:
10. Trying to buy used instead of new parts.
9. Not caring too much about my oil leaks.
8. Vacuuming.
7. Putting on my front license plate. No more worries with cops.
6. Getting my parking brake to work.
5. Upgrading to 1980 leather seats for my 1973.
4. Going to one battery instead of two.
3. Re-jetting my Webers
2. Rubbing baseball glove conditioner into my seats (same oil
as the expensive car conditioner). Went from cardboard to butter.
1. Joining this site and finding other Porsche owners
Inexpensive things I want to do:
1. install dead pedal
2. shorten shift kit and bushings
3. find Momo knob
4. front trunk brace
5. clean dried battery acid out of my truck!
6. replace tranny fluid
7. do an oil change
8. shine up my fan
9. clean underneath
10. go after oil leaks
What about everybody else? I love this thread.
Kelowna, BC Canada
'73 911T 2.7 w/Webers
Old 09-18-2002, 05:05 PM
AirCooledExcellence's Avatar
OK, I'll have a go!
1. Rebuild Brake Calipers
2. Brake Pads
3. Brake Rotors
4. Flexible Brake Hoses
5. New Badge
6. Heater Valves
7. Turbo Tie Rods
8. New Lug Nuts
9. Bleed Brakes
10. Bump Steer Spacer Kit
Have fun!
Cheers,
Tim.
____________
1983 SC Targa
Old 09-19-2002, 01:26 AM
Lowered it---FREE!!! Improves looks and handling.
It goes faster then I can drive it.
Old 09-19-2002, 03:49 AM
StanChung's Avatar
Chas,
How is your bump steering?
Kelowna, BC Canada
Old 09-19-2002, 04:04 AM
thrown_hammer's Avatar
Okay here we go...
1)Removed all sound deading materials I could find...Free
2)Tinted the windows while they were out...$35ish
3)MOMO shift knob...$70
4)Lowered the car...Free
5)Polished the fan...$10
6)Homemade Magbra...$16
7)four wheel alignment per Bruce Andersons specs...$30
8)new carpet from Tweeks fest...$25 (stole it didn't I?)
9)Used Pca coupon at Brumos... $200 worth of stuff for $60 including indoor/outdoor fitted carcover
Keeper of the Titanium Monkey
1975 911S (sold)
1973 911 w/3.2 (sold)
1983 911SC targa (sold)
Looking for a 987.2 or 981 Cayman
Old 09-19-2002, 04:20 AM
MonkeyBoy's Avatar
Dual cupholders/armrest. Made a big difference.
Old 09-19-2002, 05:30 AM
Stan, haven't had a problem with bump steer at all. I have had to readjust it about a million times because I have 18" wheels, and I was a having a problem with rubbing. The lowest I can go is 25" up front, which is fine because it looks great.
Old 09-19-2002, 05:40 AM
Lot of good/great low cost mods. But the #1 thing IMHO is this post
Originally posted by Don Plumley
Best Thing I've done with my Car:
1) My First Autox!
Don
Learn to drive your car. There is nothing that will give the biggest and longest return for less than $25 and there's nothing you have to do other than take the beer cans out and add a couple pounds of air to the tires. Learn to drive your car as it sits.
Old 09-19-2002, 06:10 AM
1. Polished fan
2. Hand painted center caps
3. Clean wheel wells and shocks
4. Replaced girl friend
What are the "bow ties" on the air vents? Thanks.
Chuck
1987 911 Targa
1962 C182
"Dirt is permanent. You can move it around, but you can never destroy it."
Old 09-19-2002, 07:02 AM
kbruz's Avatar
lunch for my wife and her friend 50.00
sixs pac of beer 7.00
bucket of soap no much
wenol polish 10.00
A quite morning with the car and a beer. priceless
kb
mercedes GLK350
2009 boxster s
86 targa
Old 09-19-2002, 10:41 PM
