johnman001's Avatar
3.2 engine swap question
Here is a 3.2 engine swap question.
I have nearly completed an engine swap of a 3.2 into an earlier car (74). The owner supplied an oil tank from a 3.2 car (which is installed). I have the two large hoses (from the case breather and to the intake manifold) hooked up to the tank and have one smaller fitting on the tank left.
After researching PET and other parts lists, I see that I am missing several items that appear to be part of the PCV system.
One item I missing is an air valve controlled by a very small diameter hose that branches off of the same fitting that controls the fuel pressure regulators. I'm not sure of the function of this NLA item.
I am also missing the NLA PCV valve (which I am assuming is a run of the mill PCV valve), the air valve mounting bracket, and the special hose that accepts the PCV valve to the tank fitting.
How important is it to have the Air Valve instead of simply adapting a hose with a PCV valve?
All opinions are welcome.
Thanks in advance.
John Flesburg
2016 981 Boxster S.................| 1983 911 Turbo - (White)
1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver)
1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?)
1971 914 (TBD)..................... |
Old 09-30-2012, 10:02 AM
kodioneill's Avatar
That's a good question, others sure to chime in. I know that part has been superseded and it's expensive. $125.00 +
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 09-30-2012, 11:50 AM
I am also highly interested in this valve and its either: Use/requirement...or can i chuck the f*cker. Just deleted my entire ac on an 88 and this valve withh associated tubing is still there. However, the small tube end came off of somewhere in back of manifold and i cannot find where..
I am concerned as now the engine idles at about 1800 rpm.... Suggesting an air/vaccuum leak? Look forward to a reply from the brain trust thanks frank
Old 09-30-2012, 04:49 PM
E Sully's Avatar
When I put a 3.2 in my 1973.5 I just plugged this line since there was no fitting on my oil tank for it. I also don't drive the car in the winter so it was not an issue for me.
Ed
1973.5 T
Old 10-01-2012, 05:01 AM
ed thanks very very helpful. where did you plug it ? did you remove the whole assembly and plug the holes in the manifold? ...or just the big hose going from the air valve to the oil tank ? do you happen to know if the temp valve is wired to the engine management system or is just sensing ambient temp at the valve. thanks frank...
Old 10-01-2012, 05:16 AM
E Sully's Avatar
It isn't tied in to the engine management, just ambient temp. I was a little lazy and just plugged the hose.
Ed
1973.5 T
Old 10-01-2012, 05:33 AM
johnman001's Avatar
Ed, Is that from the Bentley manual?
I didn't look at that.
If item "D" is a temperature controlled valve that only opens at below 10deg C, this would explain why I have never witnessed vacuum at that port (open on the other 3.2's that I have swapped).
It's interesting that the PCV valve only operates when the temperature is below 10 deg C.
Can anyone verify that the air valve "E" only opens up when the temperature is below 10 deg C?
John Flesburg
Old 10-01-2012, 10:36 AM
bump for more comments.. this topic not well covered in pelican thanks to all..still confusing to me... can one plug all 3 holes in the intake manifold and just get rid of everything? thanks!!
Old 10-01-2012, 03:35 PM
Plug the hose that goes to the throttle body unless you are intent to install a Carrera oil tank.
Bruce
Old 10-01-2012, 04:04 PM
johnman001's Avatar
The conversion I'm doing has a Carrera oil tank. This is what started my confusion. I'm intending on at least getting a PCV valve and inserting it into the smallish line between the tank and the intake, but was unclear on the function of the vacuum controlled air valve in the PCV valve hose.
John Flesburg
Old 10-01-2012, 04:57 PM
E Sully's Avatar
D is a temperature switch that opens when it is below 50 F. It allows vacuum to open valve E to allow warmer and drier air from the oil tank to the throttle body. I would think that Porsche engineers found that at low temperature, the low pressure area on the engine side of the throttle plate would cause ice to form in the throttle body until the engine warms up. If you do a search, you will find old posts where the valve E is known to make a buzzing or humming noise when it is failing.
Item C seems like a pcv valve, but without the control valve E it will continuously allow air in, which is probably not an ideal situation for higher engine temperatures. If you are going to drive it in cold weather, I would say to get the complete setup.
Ed
1973.5 T
Old 10-02-2012, 06:12 AM
Thanks Sully That is the clearest indication of its functions and requirement yanking and plugging it all of it this weekend!! uThanks again Frank
Old 10-02-2012, 08:14 AM
johnman001's Avatar
Well it's installed now. The best way I could think of. It should function as the designer intended.
John Flesburg
Old 10-09-2012, 06:05 PM
BoxsterGT's Avatar
Porsche Crest
John-
I am curious as to the condition of the original white Nylon fuel lines thru the tunnel on the 74 chassis.
Did you replace them with new factory Polyamid lines?
Nice install, clean 74 911.
Len
Old 10-10-2012, 12:52 AM
johnman001's Avatar
Yes, brand new factory lines for a 3.2.
John Flesburg
Old 10-10-2012, 03:51 AM
johnman001's Avatar
Originally Posted by BoxsterGT View Post
John-
Len
John Flesburg
Old 10-10-2012, 07:07 PM
johnman001's Avatar
I could build more like this one. This one, however, is for my dad and it is more than a gem. I'm really taking the time to do everything "just right". My dad has been a HUGE influence in my life and I want to make this toy the best I can. He did sacrifice his first Porsche and committed it to a full time track car because I wanted it that way. In a sense, this is my way of paying it back. I could not imagine of paying it forward, with so much as I owe to my dad.....
John Flesburg
Old 10-10-2012, 07:15 PM
johnman001's Avatar
It's running!
John Flesburg
Old 10-30-2012, 06:58 PM
non-whiner
mreid's Avatar
That is a beauty, John!
"Too much is just enough."
Old 10-30-2012, 07:11 PM
Old 10-30-2012, 07:51 PM
