shift coupled problem
I just got a new shift coupler from our host. it moves in all directions alot.the black bushings allow the pin to move side to side and up and down. big gap between shaft and bushing.
![]() ![]() can this be right they move more than the old one.i thought it was suppose to be tight?
1982 guards red 911 sc work in progress ![]() |
Normal.
Don't worry mate.
LIGHTER = FASTER !!! |
search "coupler whisperer"
Ed M 86' Coupe |
Yes, coupler whisperer. You will not be disappointed.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
Go-Kart Mozart
how does it tighten up shifting if its that loose?
Go-Kart Mozart
Ed's bushings aren't loose. Made from different material and machined to closer tolerances. Lots of info in these threads.
J The Coupler Whisperer Eds shift coupler |
+1 on ivangene's coupler bushing..made a huge difference to my poorly shifting SC. Now there is very little hesitation going up or down the gears.
15 year PCA member ![]() 1972 911 E Coupe - gone now 1987 Mazda RX-7 2+2 - still cooking Swift DB-1 FF & Swift DB-3 F2000 -not forgotten 1979 911SC 3.0 & 2000 Camaro |
Ed M 86' Coupe |
Living the Good Life
+1 for the coupler whisperer.
Chris 1974 911 |
thanks i will look in to that. the replacement i have will not due. thanks everyone....carl
Thread Tools | |
Rate This Thread | |
