LinkBack Thread Tools Rating: Thread Rating: 5 votes, 5.00 average.
1978 911 Targa A/C add on
I have a 1978 911 SC Targa. Presently the engine (3.0) is being rebuilt, but no A/C. Is this the time to add the A/C, secondly is who offers a dependable and complete A/C unit, third does the dash need reconfiguration, and lastly is it worth it?
Old 10-22-2012, 08:13 AM
Dave Colangelo's Avatar
I also have a 78SC Targa with no AC. It has never been an issue for me, in the summer I always roll with the top off so AC is really a non issue for me even on the hottest of days. It really depends where you live. I live in NY and the summers get hot but never really that bad, i you live some where in the south or a place where the heat is really bad than that may be a different issue. Where are you located?
I would say its not worth it but that is just me. Look at it this way, you will most likely be looking at around 1.5K for the stuff (or at least that is what I have heard from people who have upgraded to decent working systems) I have no idea if that is all new parts or upgraded existing parts. It has long been known that the AC systems in these cars are only ok at best which is some thing to consider as well. There is also the addition in weight which may not be an issue for you but many would not be happy about that. Think about how often you would use it and if it is worth it for you. I also do not if its as simple as bolting on the compressor and running some tubes so you may want to look in to what it will take.
You will not have to modify the dash, i believe the AC controls were traditionally mounted in the center console.
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 10-22-2012, 09:00 AM
ROW '78 911 Targa
timmy2's Avatar
Guess it depends on where you live as to if you need it. I just took mine out as it didn't work and almost started a fire.
If you have a dire need and $5k+ burning a hole in your pocket then go for it.
Vent system will need to be modified.
Old 10-22-2012, 09:03 AM
pavegeno's Avatar
Send a message via Skype™ to pavegeno
Here is some great background info...works exactly as advertised...got mine while in south Florida and have been completely satisfied...the "hurricane fan" is essential.
Porsche 911 Air Conditioning, Porsche 930 Air ConditioningUpgrade Updates,Improvements
Old 10-22-2012, 09:28 AM
wwest's Avatar
If you can find a "salvage" 911 carcass the OEM A/C system will work just fine.
The only actual shortcoming of the factory system is the lack of refrigerant condensing (cooling) capability. You can easily and inexpensively overcome that problem, and improve system relaibility. Just add a trinary pressure switch in the high pressure line at the compressor, use one set of sensor switches to control the compressor clutch on/off cycling and the second switch to control 2 12 volt radiator fans to provide "make-up" airflow through the rear lid condensor when the engine RPM isn't high enough for adequate condensor cooling airflow.
Old 10-22-2012, 02:39 PM
kuehl's Avatar
Jim,
1) You can add AC at any time, engine in or out.
The benefit of doing the job with the engine out is bolting on the SC style
compressor strut mount to engine console, and if by chance your crank pulley
is not a 2 groove you'll need to bolt one on; it is a bit easier to do these 2 tasks engine out of the car but I've done both ways over the years
2) Since EVERYONE (experienced owners) knows
the stock system 'out of the box' from the factory was inadequate and not reliable, otherwise you would not find thousands of posts here on Pelican or the Rennlist about AC, you know right off the bat what ever you do will need to be better. Period. The shortest path to that solution if a mixture of the old and new. The old being certain 'used' components that are simply less expensive to source used vs. new. The 'new' components being improvements. If you drop me a PM we can get you down the logical path.
3) Is it worth it?
Well you know that is always subjective, an opinion.
The question comes down to how hot and humid your climate is and how many days a year you want to drive your car in those situations: is your car a weekend warrior with no other occupants, or is going to be a daily driver.
I tend to look at it in these fashions:
A) Do you want the car to die before you do, are you going to really drive it as much as possible and enjoy it?
B) Engine rebuild $10k+, tranny rebuild $3k+, body and interior fixes $$$$,
stereo upgrade $500+, tires, shocks, etc. Spend all that cash and if you don't have a good AC system well ??
So the price to have a comfortable cockpit is priceless!
Old 10-23-2012, 07:48 AM
wwest's Avatar
Originally Posted by kuehl View Post
Jim,
Inadequate, yes. But only inadequate in the sense that more refrigerant condensing, cooling capacity, was/is needed. Don't trust me, just have a look at what Porsche first did to first address that fact.
and not reliable,
No, simply NOT the case. I have 2 911's, an 78 Targa and an '88 Carrera, both with well over 100,000 miles and other than the refrigerant laskage problem and having to replenish the R134a about every 2 years NOTHING has failed. Oops, I take that back, the front comdensor blower got VERY noisy. But the goods ne was that as a result of the fans on the rear deck I didn't need that fan so I simply removed the fuse.
If there is any question of reliability it would be due to the failure rate, life, of the thermostatic compressor clutch control. But the easiest way to tackle that problemis by adding a binary (or trinary) pressure control sensor.
Yes, there can be NO QUESTION, historically, that you would have needed to go to one or more of the aftermarket components.
But, this be a NEW DAY. What was, is no longer, all that is left for the aftermarket sales is......SNAKE OIL...!!
Yes, couldn't agree more... New being a 2 12 volt fans and a trinary pressure switch to control both the fans and the compressor clutch. And the leakage issue? It may very well be that preventing the engine lid condensor's temperature from rising too high might well also alleviate that problem.
The old being certain 'used' components that are simply less expensive to source used vs. new. The 'new' components being improvements. If you drop me a PM we can get you down the logical HIGH PROFIT MARGIN path.
3) Is it worth it?
Comfortable cockpit is priceless!
In other words, either bring DEEP pockets or don't come.
Old 10-23-2012, 09:03 AM
kuehl's Avatar
West. Grow up!
Old 10-23-2012, 09:09 AM
Scott R's Avatar
Yea, forget the 12v fan idea. That's the real snake oil. Factory could have put fans all over that rear condenser back in 78 but chose not to, and there is a simple reason why.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-23-2012, 10:06 AM
wow, that's cute
Old 10-23-2012, 12:13 PM
wwest's Avatar
The type (voltage, CFM etc.) of radiator fans needed did not exist in 1978, they only became readily available with the advent of FWD, and only became reasonably inexpensive with the more widespread adoption of FWD.
Besides which in that era Porsche seemed to be turning to Lucas Electric for the blowers/fans used up until about 1990.
Old 10-23-2012, 12:40 PM
Scott R's Avatar
They had them, one is installed in the front that's perfectly adequate. Plenty of 12v high CFM fans available since the invention of the electric fan. It's just pointless attached to the bottom of the 911 deck lid condenser.
Well unless your goal is to block the flow of air to the engine of course, then mission accomplished.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-23-2012, 01:00 PM
Send a message via AIM to fintstone
Cool
I would highly recommend installing an A/C system if you can afford to do so, but it is not cheap if you have none of the parts. You can do it in phases. You will need a bolt-on under dash vent system like on the earlier middies. I did like Griff suggests and put the double belt pulley and bracket on while the engine was out and then collected the remaining parts while I drove the car. The system was well worth the cost as it allowed me to drive my car in Albuquerque year round. Why shouldn't a 911 have a working A/C when even a KIA does? Since I never plan on selling my 911, it is a reasonable cost amortized over many years of enjoyment. The aftermarket Kuehl system installed in my '74 worked much better than the fully functional, freshly serviced R12 sytem in my low mileage '89 Carrera.
The dual Kuehl system that Jim Sims installed on my '74 a few years ago worked great...about 34 degrees at the vents with R134. Kuehl parts worked amazingly well and required no cutting of my car (there is a very good thread here devoted to Jim's install...Jim did an amazing job).
Kuehl...Griff Unfortunately, I was hit by another car and mine was totaled. Although it was a pretty bad collision and totaled both cars, it was a front end collision so most of the A/C system was spared. I kept the car around for a year or so and the engine still ran perfectly, and the A/C was still ice cold despite the serious impact. Eventually I pulled the engine, tranny and A/C as donors for another '74. I have installed part of the A/C system in my "new" '74 as well, but have a few parts missing (like the rear wheel well stone guard). Some of the barrier hoses also need replacement. Do you sell replacement parts like these outside of your kits? Also I am on the east coast now, so I am curious if you have a shop that does installs or just sell parts. It is taking me forever to get to this as I work almost all the time these days and would be happy to have a pro finish the remainder.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 10-23-2012, 06:30 PM
kuehl's Avatar
Jimbio,
Swing over to the Pelican classifieds here:
Porsche 911 Used Parts For Sale & Wanted - Pelican Parts Technical BBS
You can do a search (tab is on the right top side of all forum headers)
for AC, A/C, air conditioning (all the logical key words) in that forum
and look for someone parting out, say a 1978-1983, 911. You want
everything they have to offer but the hoses, drier, thermostat and compressor.
If you are serious about an ac project we can guide you in more detail.
In terms of 'vents' for your year car, you don't want a knee pad vent, rather you want the guts to the ventilation components from the evaporator box to
the vents from the 78-83 for example.
Flintstone
Glad to hear you had a positive experience with our Kuehl products; a kudo now and then does tell us we are doing something positive for our community. Feel free to contact us if you need help with your next project.
Best Regards,
Griff
I don't want no garage queens or weekend warriors in my parking spot. I want my car to die before I do.
Old 10-24-2012, 04:16 AM
My bad (above)...I didn't realize the '78 didn't still use the kneepad distribution setup (never ridden in one that new except for my '89)...That should make it a lot easier to source.
Old 10-24-2012, 11:34 AM
wwest's Avatar
Jimbio,
Using a new drier I can understand, but why the hoses and thermostat...Both might very well be perfectly good and fully functional.
and compressor.
Sure, "scrap" what might be a perfectly good, fully functional, compressor for a rather expensive new one with substantially lower displacement volume. Is that a bit like jumping out of the frying pan directly into the FIRE...??!!
Flintstone
Best Regards,
Griff
There is quite clearly an "old school", historical, belief that the refrigerant leakage over time can be attributed to the use of "non-barrier" hoses in these early 911s. While that might well be true there is an anomally...these same hoses were widely used elsewhere in the automotive A/C industry. So just what might be the difference in our 911's..???
Engine heat rising through the rear lid condensor AFTER the engine is shut down?
Via testing this specific circumstance I have satisfactorilly proven, at least for myself, that high side refrigerant pressures could easily rise high enough to possibly by-pass the o-ring seals, or even as others contend, force refrigerant molecules through the non-barrier hoses due to pressures they are not designed to withstand.
So the answer might well be to provide condensor AND engine cooling airflow POST engine shutdown.
Old 10-24-2012, 11:41 AM
kuehl's Avatar
Simply for the sake of redundancy for those, ahhh.. believers of unproven propositions,........... we will go over what is factual, well known in the 911/930 community for many many years, and discussed in thousands of threads through out Pelican, Rennlist and other sources: ....
Most cars are front engine and the compressor, evap and condenser are located in the front near one another. Hence they typically used 10 feet or so of non barrier hoses prior to the introduction of R134a in the early 90's. A 911/930 is quite different, the engine is in the back along with 1 condenser while the evaporator, drier an another condenser are located in the front, hence there is 40+ feet of hose in these makes. Does the refrigerant leak out of the non-barrier hose? Yes. Its been proven in many studies, that is why barrier hose is a requirement to slow/stop the permeation leaks no matter what refrigerant you use. And, for those of us whom are experienced and wiser, replacing the hoses reduces the permeation rate. And, quoted from the shop manual section 800-9, " There are almost always small leaks in the system that will require that it eventually be recharged....".
Did you ever wonder why with the introduction of the 964 in 1989 they decided to use very expensive aluminum tubing from the compressor side lines up to the front of the car? "Rate of permeation".
Yes. Heat does rise from the engine. However, as soon as the compressor turns off the pressure in the refrigerant system drops and equalizes. For example: assuming you are operating the AC system on a hot day, let's say its 100F outside and your operating high side pressure is 280 and low side is 35. You turn off the compressor and the engine as well. If you had a set of gauges on the system you would see the high side drop and low side rise. In short period of time they will both equalize to,... let's say 100 psi for example. The residual heat from the engine does NOT drive the pressure back up because there is not enough BTU's: radiant, convection or whatever your source of heat is. Not enough BTU's .... period. And since the static pressure of 100 is less than the operating pressure of 280 the chances of the system system loosing refrigerant because of engine heat are not probable. If you have faulty o-ring seals or leaks in other components you are going to lose refrigerant at a greater rate when the system operating.
Many people complain that they had their systems recharged in the summer and the following season they have lost refrigerant, however their technicians cannot find the source of leaks with either black light & dye or electronic sniffing. This is because of the slow permeation rate (xxx parts per million x given time) through the hoses was the cause and cannot be detected with the dye or sniffer.
... but why the hoses and thermostat...Both might very well be perfectly good and fully functional.
Hoses have been discussed, however you do have the only unusual Porsche here
so don't worry about. The reason we suggest to replace the thermostat is simple:
A) If you have ever purchased a used 25 year old thermostat that has 36" of 2mm nominal OD soft hardness aluminum tubing filled with a gas, that has been ripped out of a car, stored in a garaged with piles of junk on top, and the shipped to you.... well, you would know better.
B) After 25 years of operation: bellows opening and closing, contacts making and breaking .. things get tired.
So the answer might well be to provide condensor AND engine cooling airflow POST engine shutdown. .
Please proceed with designing of your devices and post your pics and results here when your done.
Old 10-24-2012, 01:17 PM
wwest's Avatar
That's a 4 to 1 ratio, if what your surmise is true wouldn't that mean the cars with only 10 feet of hose would lose the refrigerant at an equal ratio, 4-8 years for 10 feet, 1-2 years for 40 feet?
My best example would be our 1968 Ford country squire station wagon. I have a memory of laying the compressor on the fender so I wouldn't have to recharge the system after I pulled the engine for overhaul at 125,000 miles. That car went to the great junkyard in the sky in 1978 with ~278,000 miles and the A/C still operational.
Or bypass the o-rings due to over-pressure?
Yes.
Name, refer me to a couple of those, if you please.
But why has this issue NEVER been raised outside the Porsche community?
And, for those of us whom are experienced and wiser(??), replacing the hoses reduces the permeation rate.
No question here, newer, improved technology components abound all around us. The question "here" is would the "non-barrior" hoses work just as well if the over-pressure matter were resolved.
I have put a LOT of miles on quite a few air conditioned vehicles in my 72 years of life and other than the 911's not one has had to have the refrigerant replenished on a "maintainance" basis.
"Rate of permeation" or rate of rock hits?.
So, they chose aluminum tubing over "barrior" hoses, maybe there is a message there that you missed?
Not if the evaporator vane surface area(s) are already at 33F when the engine is shut down. I have already proven that the TXV remains closed for quite an extended period of time, minutes, in this instance. Check it out yourself if need be.
I only had a low side guage but it remained at the operational low level indication long enough that I was satisfied of my theory.
I guess we need to define "short period". With the evaporator already at 33F and no system airflow how long would you suppose ot might be before the TXV opened...??
If memory serves mine settled at 70PSI.
Nobody said the pressure had to be driven "back up", my contention is that on occasion the high pressure side is already well elevated when the engine is shut down.
"The proof is in the pudding". Try the experiment, it should be easy enough to prove me wrong.
Wrong foundation for your argument, try starting at ~290PSI, or more (R134a).
No one "said" faulty o-rings nor "faulty" non-barrier hoses, just more system pressure than the system was design to handle.
Please note that would also be the case with my theory, the o-rings are only compromised at/during the rare times of over-pressure, same with the non-barrior hoses.
No, I would use a standard ice bucket test to prove that the thermostat contacts opened and closed reliably at/near the maximum cooling setting.. AND I would add a pressure sensor switch to over ride the thermostat if system pressures warranted
Somewhere around here I think a still have my USAF issued (~1958) relay contact file set should the thermostat contacts need "dressing".
Old 10-24-2012, 03:09 PM
