cjannelli's Avatar
speedometer gauge light
The upper gauge lamp on my speedometer is out. For good measure, I replaced all the gauge lamps. The upper lamp on the speedometer still does not work unless I pull the headlight switch out to illuminate the parking lights only. When I do this, the gauge lamp works. When I pull the switch all the way out, the upper lamp goes out. All the other gauge lamps remain on. Wondering if anyone could shed some light on this
confusion(sorry). Would there be any reason I couldn't splice the upper lamp to the wiring for the lower lamp?
Chris J
Old 10-19-2012, 12:28 PM
I'm not sure if we talk about the same thing, but if there is a symbol printed on the top of your speedo dial that looks something like this "=D" and the lamp is green, then this is normal. The lamp (I think your are talking about) indicates that the light switch is only pulled to the parking light position and not all the way.
'86 Carrera Cabriolet Grand Prix White
'09 VW Beetle Convertible
‘24 Audi Q8 etron
Old 10-19-2012, 12:55 PM
cjannelli's Avatar
speedo gauge lamp
I'll pull the gauge and check again. Thanks
Chris
Old 10-19-2012, 01:14 PM
Daviboy's Avatar
cjanelli this is how mine work in my 82 SC as well
Old 10-19-2012, 01:25 PM
cjannelli's Avatar
The upper lamp that should illuminate the gauge is the one that goes out when the light switch is pulled out completely. I'm going to check and see if the wires/bulb are in the right sockets. I suspect they were accidentally switched.
Chris
Old 10-19-2012, 01:32 PM
I think I understand now what you are talking about. Does the green light on the top of the dial stays always on when the lights are on? If that is the case, then someone switched wires.
‘24 Audi Q8 etron
Old 10-19-2012, 03:06 PM
Could be that the bulbs are in the wrong sockets. Try moving the bulbs to different sockets, that might solve your problem right there.
2007 Cayman
1986 Carrera coupe (sold)
1979 911 SC targa (sold)
Old 10-19-2012, 03:25 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Chris J
Chris, this is normal, green light is your warning idicator that running lights are on but not the head lights, I believe it was a DOT requirement.
'85 Carrera Targa
PCA/POC
Old 10-19-2012, 03:26 PM
cjannelli's Avatar
yes, the green light stays on. Makes sense now. Thanks guys!
Chris
Old 10-19-2012, 03:27 PM
