RETIRED
Joe Bob's Avatar
Failing headlamp switch?
My headlight switch sometimes needs a tap on the pull out or a turn on the rheostat to get the dash lights to come on.
Failure notice on the switch or a loose connector? They are a PITA to get to and to test.....anyone BTDT.
2012 ML350 3.0 Turbo Diesel
Old 10-19-2012, 01:33 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Headlight Switch.
Could be a dirty/corroded switch wiper.
In my opinion, pull the switch, clean the wiper.
No joy, replacement time.......
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 10-19-2012, 01:55 PM
AutoBahned
RWebb's Avatar
got relays?
this often seems to indicate incipient failure, but could just be dirt & crud in there -- hose it out with elec. contact cleaner and see if that fixes it
Old 10-19-2012, 02:28 PM
RETIRED
Joe Bob's Avatar
Yep....relay kits for both the H4s AND the driving lights. Looks like I'll drag out the Bentley and start a diagnosis....
Old 10-19-2012, 02:30 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Hey M,
I attempted to rebuild mine but ended up replacing it, the rheostate just worn out.
If you do get a new one re-check the mechanism, for some reason the quality is not the same from PAG and I had it replaced. It should be a smooth but snug movement.
J
'85 Carrera Targa
PCA/POC
Old 10-19-2012, 03:29 PM
