Leland Bushing Help
Trying to install a Leland steering bushing and can't get the bushing on far enough to attach the C clip. Besides the 1st C clip must I also remove the C clip I see on the bearing? I believe that's what the instructions are telling me but just want to make sure before I try to get the 2nd C clip out.
The pic shows where I'm at with the install Thanks Carl
Has the old bearing been previously replaced with the 928 bearing? There should only be the one C clip to remove (I just did this last week).
Kurt |
Yep, just pulled 1 C clip. The other bushing was completely gone.
break fix drive repeat
How hard have you tried to persuade it? I used a length of PVC pipe and some light to moderate taps with a 3 lb sledge, took maybe 3 or 4 taps to drive home. I could not have done it by pressing with my hands only.
BTW -- it completely transformed the car's steering in a very positive way. |
I used a socket to persuade mine cant remember what size!!! the one I used, was a perfect fit.
Good luck
Jose 87 Carrera ( Nougat Brown ), 11 Subaru Legacy (daily driver), 08 VW Passat wagon 2.0T (wife), 03 Audi A6 2.7T (sold) ), 98 Pathfinder (sold), 02 TT 225QT coupe (sold), 03 Audi A4 Avant (wife)GONE... |
I ended up sanding some of the narrow end off and using a deep socket to seat the bushing. From the pic above you can see the bottom looks seated but still a distance to go before the C clip can be installed.
After e-mails with Mitch (great support BTW) found out I didn't get the 928 sleeve out which is why the bushing would not go in. It was in the instructions, just missed it (go figure). Now I'm waiting for a new bushing that I can install correctly.
Anyway Mitch has been highly responsive to my questions in trying to solve this issue and would highly recommend this fix over others. |
