SLR SLR is offline
SLR
Headlight relay kits
Caine me if you lick! I love a good spanking...
Just going to order the kit from PP (Headlight Relay Kit
911 (1974-89)) and was wondering if I need 2 of them or is the one kit for left and right headlights? I was told that I need a kit for each side. I'm in the UK so it makes a postal ishoe if I order wrong,
Thanks for any input Steve.
Old 11-17-2012, 04:10 AM
Been here a while
Just one....it contains 2 relays, one for the high beams, one for the lows.
looking for 1972 911t motor XR584, S/N 6121622
Old 11-17-2012, 04:40 AM
83 911SC Cab
Cherry Bomb's Avatar
X1
Old 11-17-2012, 07:52 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
JWest Kit.
Hope this helps:
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 11-17-2012, 08:04 AM
Though it's meant for US-wired cars.
I've got an '85 Euro 930 and my headlight wiring does NOT jive with the supplied instructions, and it will absolutely not just drop in. I've been sent some photos and diagrams where a member here made it work with some re-engineering. It is on my "to-do" list, but as it is now, the kit sits languishing, while I use the headlights as-designed.
Would imagine a UK car would be wired like a RoW car, so heads-up on that.
Old 11-17-2012, 08:05 AM
ROW '78 911 Targa
timmy2's Avatar
Works as intended in my LHD '78 ROW from Germany.
Study the wiring diagram and figure it out, or have it installed for you.
As an Electrician by trade, I can say it is a simple job to install, taking less than an hour to perform.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 11-17-2012, 08:42 AM
SLR SLR is offline
SLR
Thanks for the coments , I'll go ahead with the kit from PP and I'm sure I'll work it out. Now for the cigaret light socket
Old 11-17-2012, 08:55 AM
JWest.
As per my previously posted pics, all went well.
Gerry
1986 911 Targa.
Only in L.A.:
Old 11-17-2012, 09:00 AM
Chain fence eating turbo
I soooo need to do this. Original main low beam wire burned up taking out fuse panel.
Old 11-17-2012, 09:22 AM
SLR SLR is offline
SLR
Tippy"
It is a very good price to pay , because I have had to replace the switch on the steering colum and so did a freind in Australia that cost him a bundle $$$ .
Old 11-17-2012, 09:37 AM
Reifle's Avatar
I found when I installed the relay kit the dash lights improved somewhat! The installation was quite simple - added fear factor didnot help. In the end quite simple indeed. Also installed brighter bulbs - 80/100 watts. Makes a big difference!
'77 Porsche 911S
Old 11-17-2012, 11:27 AM
Formerly known as Syzygy
Canada Kev's Avatar
The Jwest kit worked just fine on my Euro car. It's a great piece of mind bit of kit. And the price isn't ridiculous, either.
Kevin
Old 11-17-2012, 11:38 AM
Relays.
Kev,
The Jwest relays are not the best.
I replaced the JWest relays with Bosch.
Gerry
1986 911 Targa.
Only in L.A.:
Old 11-17-2012, 11:53 AM
Canada Kev's Avatar
Well, at least it's easy to swap them out. If one wants to change them, your FLAPS will likely have something to suit. The whole installation is pretty straightforward.
When I decide to do it all up right, and to handle 100/80 watt bulbs, I'll replace the wiring with heavier gauge and use ceramic headlight plugs. These relays are no brainer easy to do and should almost a requirement.
Kevin
Old 11-17-2012, 12:09 PM
Tippy"
Yeah, I've been lucky. Thanks for more encouragement. Going to buy the kit soon.
Old 11-17-2012, 01:07 PM
HarryD's Avatar
As an alternative, you can buy your own relays and make the kit. This the the way I did the wiring for a 1973 and earlier car:
You will Ned to determine the correct fuses from your wiring diagram.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-17-2012, 07:01 PM
87 - 911
When I received the relay kit I too thought my wiring didn't match their diagram, sent JWest an e-mail along with a picture on Sunday afternoon, received a reply that evening. All was well and went ahead and installed as per instruction sheet.
Can't beat service like that for a part that costs very little.
Old 11-17-2012, 07:16 PM
nineball's Avatar
BEST QUALITY H4 / 9003 High Temperature Headlight Socket / Plug / Connector. We Welcome Custom Orders! All of our Head Light Sockets / Plugs / Connectors are made with USA Wire! - Innova Design & Dist. Inc. (909) 971-0000
i bought a set of these and was very happy with them.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 11-17-2012, 09:09 PM
HarryD's Avatar
When I got my kit from Daniel Stern, it included these sockets:
They are Hella Part number 001909001.
Harry
2020 MB E350 4Matic
Old 11-18-2012, 10:30 AM
Drisump's Avatar
I have an 85 Carrera Euro and the installation was just as described in the instructions.....so maybe the 930 is an anomaly. Cheers
Old 11-18-2012, 11:14 AM
