Oil cooler not getting warm--what's wrong??
I have a B&Bfront oil cooler behind the front valance that is not hot to the touch(or even warm) after a track session and my engine temps are too hot. Front fender carerra cooler is heating up fine but not keeping up. Any ideas on what could be happening?
1980 911SC Targa 3.6L
Old 10-27-2012, 04:18 PM
Wer bremst verliert
JohnJL's Avatar
Sounds like your thermostat isnt opening. Are the lines on the engine side of the thermostat hot?
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 10-27-2012, 04:55 PM
scotricker's Avatar
Well, how is it plumbed? Where do the hoses come and go from? Is the front cooler in-line after the fender Carrera cooler? Is there another thermostat along the way?
Can you post a diagram of how you've got it all hooked up?
Scot
78 911SC coupe, sold,, 2019 Macan S
"my friends all drive Porsches, I must make amends.."
Old 10-27-2012, 05:51 PM
Senior Advisor
James Brown's Avatar
should go, hot engine oil to the fender cooler, out to the front cooler, out back to the oil tank.
08 Cayenne Turbo
Old 10-27-2012, 06:18 PM
Both lines were hot. Does the B&B have it's own thermostat maybe? Possibly plugged internally? I bot it used and supposedly cleaned out per seller.
Old 10-27-2012, 06:35 PM
Senior Advisor
i don't understand, you said it was not hot, now they are both hot?? can you tell us the routing of the oil lines. most oil coolers do not have internal thermostats
08 Cayenne Turbo
Old 10-27-2012, 06:39 PM
Laneco's Avatar
Some oil coolers, like the old RX7 coolers, do have internal thermostats. We've got an RX7 cooler in Steve's cabby and another sitting at the shop - definately have internal t-stats. Whether B&B does - I have no idea.
angela
Hello
Old 10-27-2012, 06:50 PM
Senior Advisor
the b&b coolers do not have a thermostat built in
08 Cayenne Turbo
Old 10-28-2012, 04:08 AM
non-whiner
mreid's Avatar
It doesn't make a lot of sense if they are plumbed in series - fender cooler to front cooler to oil tank. If the fender cooler is hot, how does the oil get back to the oil tank without going through the front cooler? If they are plumbed in parallel, then any obstruction in the line or cooler would cause the front loop to be bypassed, but the lines wouldn't be hot. Very strange...
"Too much is just enough."
Old 10-28-2012, 06:52 AM
It is very strange that the front oil cooler would not be hot yet the lines would be. One side of the cooler where the inlet/outlets are was slightly warm and the other cold to touch. Not sure what could cause this other than some type of obstruction in the B&B cooler that is causing the oil to take a short cut inside the B&B and not flow through the cooler.
Old 10-28-2012, 10:05 AM
