procan's Avatar
What's the max hp you would put on 215-225's?
I'm looking at an engine upgrade/swap on my '69, and i want to keep my narrow flares. The max width I could comfortably get away with is 215-225's. What is the max hp you would feel comfortable putting to those wheels?
Old 10-26-2012, 01:43 PM
"O"man(are we in trouble)
widgeon13's Avatar
I'd say you can put 250 HP at least but don't think you will ever get there. I had approx 230 HP on a 74 narrow body, no problem.
Old 10-26-2012, 01:54 PM
83 911SC Cab
Cherry Bomb's Avatar
My 3.2L equipped '83 SCWB is running 215/55 rears while new tires are being selected for the Fuchs. I will then go to 225 or 245, looking like 225 based on selection vs. purpose. First gear is near useless at times and the rest works well in all situations.
Remember, the smaller the footprint, the more weight distributed across the contact patch = traction! It's all in the compound. My '63 VW Bug had 215/65/15's and spun'em for miles. I swapped in a set of 165R15's for a time and '60 increased as well as gear change traction.
Run the smallest, read: lightest tire you can and have the least amoount of rotating mass. Accelleration will be fun!
My $.02
Old 10-26-2012, 05:18 PM
procan's Avatar
I heard about "R" wheels or something that give an extra inch on the inside. How much clearence do these give?
Old 10-26-2012, 05:42 PM
Charles Freeborn's Avatar
What's your driving skill level, and what do you expect to be able to do with it?
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 10-26-2012, 06:33 PM
I think it more about what the tires/wheels are tied into than the size of the tire.
Old 10-26-2012, 07:18 PM
Send a message via Yahoo to Lukesportsman
'R' wheels often require spacers so just take car if you go that route to slip 7"s in there.
Compound is as important to traction and design to slip angle as the actual size. I run 240hp on 225's 15's on my track rat and she is a ball. Controlled slides with lsd whenever you want and it rotates quicker than my big tired cars at safe street speeds. You could always change gear stack if you need to control power delivery....don't restrict the hp
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 10-26-2012, 07:29 PM
bill romero's Avatar
I had 951 16X8" Fuchs on all four corners of my early (narrow body) car with 225/50/16 & didn't have any issues.
'63 356 S90 Ivory/Red
'70T coupe Burgundy/Tan
'71 914 Canary Yellow
'72 Datsun 240Z Orange/Black
'65 Chevy C10 shortbed fleetside Butternut Yellow
Old 10-26-2012, 08:03 PM
Any opinions if the same could be done with 911 16x7" ET23 Fuchs on a 72-73 car without modifying fenders? Some say Yes some say "No, it will rub" but my understanding is that on a later car it should be doable without any modifications.
Old 10-27-2012, 03:03 AM
Automotive Writer/DP
Randy W's Avatar
215/50-16 on a 16x7 Fuchs on LWB narrow body is near the limit. 215/55-16 rubbed on the rear fender occasionally on my '72 911 with stiffer torsion bars and nearly two degree neg camber. Depends on the car and tire of course. '74-77 911 can usually get away with a bit tire more for some reason.
1972 S - Early S Registry #187
1972 T/ST - R Gruppe #51
http://randywells.com
http://randywells.com/blog
Old 10-27-2012, 07:11 AM
procan's Avatar
This is for street use and the occasional DE. I'm by and far an amateur when it comes to skill level.
1969 Porsche 912/911E Hotrod - Light Ivory
2003 D2 Audi S8 - Black (DD for the snow!)
1974 Porsche euro 911S Targa - Grey (Sold! Off to the Netherlands!)
Old 10-27-2012, 07:28 AM
Administrator
Jack Olsen's Avatar
I think the limiting issue will be budget, not tires. If there were no financial/technical limitations, then a 1000-hp narrowbody would be a blast to drive, so long as the throttle is not an on-off switch.
Old 10-27-2012, 07:51 AM
Some more data. I have at least 350 rwhp and the same amount of torque. On a 40 deg day my car will spin the tires in 3rd gear going 60 mph down hill. Slightly terrifying. On a wet day my car will spin the tires at 60 mph in 4th gear at anymore that 1/4 throttle. Very terrifying. On a warm day it will spin in second gear all the way to the redline. These are all going staight in corners it is worse.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 10-27-2012, 08:39 AM
LJ851's Avatar
Yee Ha!! Sounds like fun.
Old 10-27-2012, 08:47 AM
kjchristopher's Avatar
What tires?
Old 10-27-2012, 08:55 AM
Send a message via AIM to fintstone
I am running 205/55R-15 Yokohama AVS ES100s all around on 15x7s. These were the biggest that would fit on either of my narrow body '74s with 7 inch wheels. I am running an estimated240-250 hp. Plenty of tire.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 10-27-2012, 08:31 PM
Craig T's Avatar
This is the second thread where you've hinted a concern for too much HP under 205 and 225 tires. I agree with Jack Olsen, as long as the gas peddle is not an "on-off switch", you should be fine on that much rubber with anything you can throw at it realistically. The key is modulation.
I have over 300 HP on 2250 lbs in a narrow body and it's a blast to drive. I would not want to stomp on the gas at 4500 rpm in mid-corner. That requires some counter steer to keep in on the road, but that's half the fun.
I don't know the quote exactly, but it goes something like this:
Unless you can break the tires loose exiting the corner, and keep them spinning until you brake for the next corner, you don't have enough horsepower.
Craig T
Old 10-27-2012, 09:00 PM
Bland
unclebilly's Avatar
We are running 205-50-15 Star Specs on all 4 corners of the lean, mean vageen machine. It has plenty of traction and this is a 100% endurance race car.
It depends on how heavy your car is. The vageen car has to be around 1900 lbs.
My GT2 car runs 235s up front and 255s in the back with Nitto NT01s but it weighs in at 2500 lbs.
The GT2 car with a wider stance and bigger rubber steps out easier than the vageen machine. There are some suspension differences too, the vageen suspension is as stock whereas the GT2 car has 29 and 23 bars and Weltmeisster sway bars with RSR spindles.
I guess my point is this, optimal traction depends on: desired application, suspension setup, weight, and the tire you select.
Old 10-28-2012, 05:03 AM
non-whiner
mreid's Avatar
For once, it's not about size. It's about skill and material. It is just as scary to break the tires loose with 315's in a corner as it is with 215's. Spend your money on driver education now, so you can then spend it on new tires because you wear them out rather than body work (yours and your cars) today because you don't know how to drive at the limit.
My cobra weighs 2300 lbs., has 295's on the rear with 540hp. It scares the hell out of me, but I love every second and know how to manage the throttle.
"Too much is just enough."
Old 10-28-2012, 05:41 AM
Originally Posted by kjchristopher View Post
What tires?
Falken FK 451. And it is a blast to drive.
Dean
Old 10-28-2012, 01:21 PM
