LinkBack | Thread Tools | Rate Thread |
GAFB
You sure the battery isn't just TU?
Several BMWs |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Connector.
As per several suggestions, did you check the connector?
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
<insert witty title here>
Wer bremst verliert
Hi Christien,
If you want I have an extra starter you can borrow to check. I'm in King City and around all weekend. John
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
one of the red wires off the positive battery clamp, or loose? ignition switch loom plug not seated into the cowl plug? crusty connection at the 14 pin engine area plug? you can cross the battery term and the yellow wire term on the solenoid with a screwdriver to see if the starter still works.
Battery Voltage.
What does your meter show when you try to start the car?
Are the battery cable tight?
I need to check if there's power going to the starter first before I remove it - removing the starter with the engine in the car is a nightmare. But if I'm getting power, then I'll take you up on that - thanks!
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
When you say cross the battery terminal and the yellow wire on the solenoid with a screwdriver, do you mean just jumper these 2 right at the starter?
Huh, waddya know, I checked the positive terminal, made sure all the wires looked tight, then traced those wires to where they disappear into the sheath that runs throughout the car. Turned the key and the starter worked! So, I guess problem solved, but now that makes me think I have a flaky wire somewhere in the front. I'll pull the lead off and clean the terminal really well, even though it looks fine, and I do try to remember to clean the terminals at least once a year.
Thanks for all the help guys!
All glad we could help...... Pour yourself a tall one, and jump in. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 11-02-2012 at 06:11 PM.. |
Back to what I said.remove the battery terminal, clean and reattach. Make sure it is tight.
I will give them a little twist to see if it moves. Do the same with the neg. A bad connection can allow low current devices to work, but the starter requires a large amount Of current. The alt has NOTHING to do with the engine turning over. If you connect something like the red wire Wrong, u will know...in a bad way.
Wer bremst verliert
I dont understand the physics involved, but I find on my old FJ40 that if the ground wire to the battery isnt CLAMPED on there tight when I turn the key I can hear the solenoid click but the starter wont actually crank. I often disconnect the battery when the truck is in storage and discovered that even if hte clamp is pushed down hard on hte terminal so it feels tight, I get that click but no cranking. I can go over to the terminal again and push it down and get a click but no crank. That drove me crazy, thought I had a dead battery, dead starter, dead ignition switch....nope, just need the terminal crank on there like a vice.
Member 911 Anonymous
Damn, when I serviced my alternator,I was deathly afraid of those wires as not to damage them.
Glad you solved it, please post if you find any frayed wires.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
