Racetek
racetek's Avatar
Best Engine/Gearbox installation method
I am part through restoring my 76 Targa and I am close to installing the engine and gearbox. I purchased the car in bits, engine and gearbox out, so I didn't remove them. I can see that I have two options in installing them, and that is to assemble them on the bench and instal as a unit, or instal the gearbox and then instal the engine.
I can see advantages in both methods but what is the most recommended option and why?
Old 11-16-2012, 08:05 PM
Ira Ira is offline
Ira's Avatar
I've removed and installed engines in 911s from the early 70's to the early 90's. In my opinion the easiest way is to have the trans and engine installed as a unit. Trying to line up the clutch fork with the engine installed on a jack and the trans on jack will be extremely difficult.
Old 11-16-2012, 08:23 PM
Diss Member
Quicksilver's Avatar
Installing the engine and trans as a unit is WAY easier.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 11-16-2012, 08:24 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Install as one unit.
Remove the bumper, raise the rear end as high as you can so you can clear the topof the engine and roll it in.
Lower the car so the angle of attack into the tunnel is not so steep then guide it in watch all areas.
Once in raise the engine and install the remaining components, trans mount first.
A helper would be nice to have 2nd pair of eyes make sure nothing is caught. Maybe a fellow Aussie Pelican can give you a hand.
Break a leg brother down under
'85 Carrera Targa
PCA/POC
Old 11-16-2012, 08:27 PM
Racetek
racetek's Avatar
Well, what a quick and unanimous response. Many thanks to you all.
Regards
Old 11-16-2012, 09:30 PM
Certified User
billjam's Avatar
This thread might give you some ideas.
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 11-17-2012, 01:34 AM
