Anyone recognize this chip???
Bought my car in June and the service records indicate a chip was installed in 1993. I finally opened up the Motronic box to see this....
![]() Can someone tell me what chip this is? I have the itch for a Steve Wong chip but would like to know what this is for comparison. Thanks!
'87 911 Carrera Coupe (go fast, small parts / small kids hauler) '04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius") |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Chip.
Sometimes Google is your best friend hope this helps:
HN482732AG-20 datasheet and application note, data sheet, circuit, pdf, cross reference | Datasheet Archive
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Sorta helps.... curious what company this chip is from so I have a basis for comparison.
Diss Member
The type of chip makes no difference. The data that was burning into it is the only important thing and you can burn anything onto a ROM. There is no way to know what it is unless you know someone with a chip reader and then have the data from various chips to compare it to. That will cost more then a new chip...
All we know is it is "something" and it isn't stock. It doesn't have the sticker with a number on it that almost any manufacturer would put on it.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Undocumented User
be careful! the sticker is missing.... it is there as a functional part as those EPROMs were erased with a ultra violet light so cover it up, electrical tape will do just fine.
Hmm, I just put it all back together without putting tape on it. It made it since 1993 so I think a few more weeks before I get "Wonged" won't hurt.
McLaren-Tag is correct...anything from a baseline stock configuration to the latest plans for an electron drive engine could be programmed on that chip.
And yes if the window is not covered...eventually the chip WILL erase!! The only time the chip is referenced is when the ECU is reset (power removed and re=powered after a few minutes)...after that...the ECU "learns" ...so when you replace air filters...plugs...etc...please reset the ECU so that it accepts the new parts. Bob
Bob Hutson |
Diss Member
- The chip is inside a metal box. There is no UV inside so it won't get erased. (It is still best to cover the window...) - The DME doesn't "learn" and doesn't have RAM that it loads the ROM's data to. It is constantly reading from the maps directly in the ROM to select the fuel and ignition settings. Hooking to this to change those settings on the fly is how a "piggy back system" works. Things changed after the OBDII systems came into place. Those are required to have some non volatile memory because they have some pretty ambitious requirements.
Its a Hitachi; I'm in the electronics industry
-Todd '82 911 SC Coupe w/'92 3.6L, bulletproofed 915/62 w/GT LSD & Wevo goodness, Rennsport RSR/Bilstein Sport, SRP ARB, ER Polybronze, BK strut brace, 15x7/8" Fuchs. Sold: 92 964 Turbo, 81 SC, 96 993 Coupe, 82 SC, 89 Carrera Cabriolete |
Diss Member
Oh , and back to the original poster...
Get that DME updated to 28 pin when you go to change the chip. It is a worthy upgrade.
Ordered a Steve Wong 24 pin chip this AM.... the return policy made it a no-brainer in case the difference between his and what I have in their now isn't that noticeable.
My current chip has a definite lag until it hits 4k and then pulls pretty hard. I'd gladly trade for more low and midrange grunt than all out high rpm power.
Even though the chip was in a metal box this picture was taken out of the box which means the chip was/is exposed to ambient UV light. All it takes is a single word in memory being erased to cause an issue.
Regards Dave
'78 911SC Targa (Back In Action!) '00 996 Carrera (New kid on the block) '87 944 (college DD - SOLD) '88 924s (high school DD - Gone to a better home) |
Diss Member
From Wikipedia: "The process takes several minutes for UV lamps of convenient sizes; sunlight would erase a chip in weeks, and indoor fluorescent lighting over several years."
@chrisbruck: You are in for one helluva' treat with Steve's programming.
I would suggest that you are certain that you've a good idle control path (all components),..no vaccuum leaks, ICV is good-2-go,..mix is good,..ALL before you install Steve's chip. You may have to tweak the idle a bit,....but (still) be prepared for a response you've not felt before........promise. BEST! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
'77 S with '78 930 power and a few other things. |
I guess I'll find out tomorrow morning if it starts or not... took 5-6 pics with the flash to post the pic of the chip. Knowing me the camera flash probably messed it up.
The chip is fine.. you guys make me laugh
My knowledge comes from warnings that my various EE professors have given me over the years. I do understand that it would take a very long time to wipe this chip given exposure to indoor light, it is still some thing I would not want to chance. The same way that I am sure many of us would not wear a grounding strap when taking our ECU's apart, granted the chance of static shock is small I still always wear one.
Regards Dave
FYI, Ran perfect this AM even with all the flash shots....
