Robert Espeseth's Avatar
Which engine is this?
Hello folks, my son and me has recently puchased another 911SC, a 1981 model which has gotten the engine replaced sometime. We got a little confused about what type of engine that is installed, can anyone in here clear up?
The engine code is clearly stamped 930/16, and the case is the casting with the drain plug at the side as on the 3,2. So far this tells us it is a late 83 production 3 liter case.
But the serial number on the same case is *6700148*...and that does not match with what we can find in our litterature...please take a look at the picture of the numbers.
Old 11-08-2012, 10:42 AM
that is because it looks suspiciously like a file and stamp job. the font is not correct and the edges of the number casting are sharp. If you compare to a proper case you will see that the edges of the casting are beveled with a grinder and the numbers are sized differently
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 11-08-2012, 11:00 AM
OK, any theory about why people do so, what is the motivation? ...this car comes from NY.
Old 11-08-2012, 11:10 AM
Right on Dave. Not a Factory stamped serial #. At least it's not 663XXXX.
Brian
'73 Carrera RS
'71 911S coupe 'Patrick'
'16 Cayman GT4
'91 C4 coupe
Old 11-08-2012, 11:31 AM
perhaps to hide the true source of the engine?
Old 11-08-2012, 12:01 PM
ROW '78 911 Targa
timmy2's Avatar
Perhaps an unstamped replacement case?
Old 11-08-2012, 12:31 PM
db_cooper's Avatar
Looks like a replacement case..saw a few from time to time.
Old 11-08-2012, 12:40 PM
gearhead
Someone didn't know what they were doing. They took a 930/16 911SC case (likely an unstamped replacement case ) and gave it a 930/60 turbo serial number? That's a WTFBBQ if I ever saw one.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 11-08-2012, 12:47 PM
Maybe from a stolen car?
Old 11-08-2012, 05:30 PM
Danny_Ocean's Avatar
Does the stamped engine # correlate to the VIN in any way?
Old 11-08-2012, 08:00 PM
No, the engine is not correct to the car. VIN tells 81SC, the engine has the updated case that came late 83...
Old 11-08-2012, 09:01 PM
My (rhetorical) question was to Brad Beck who is implying your engine came from a stolen car. The engine #, as far as I know, isn't repeated in the VIN, so there is no need to re-stamp the block in such situation.
Old 11-09-2012, 07:32 PM
group911@aol.co's Avatar
Replacement cases didn't come with stamped type number and that appears to be a factory stamped type number. Borrowed and filed/ restamped engine.
Thanks,
Bob
group911@aol.com
Old 11-10-2012, 08:29 AM
