Wobbling Front Pulley 85 Carrera
So about 2 weeks ago I started heard a funny noise at idle and opened the hood and saw nothing funny. Then on my drive from Texas to NC last week I opened the hood again and saw that the fan belt was a little bit loose. Finished the drive and then yesterday I heard the noise again and saw that the pulley appeared to be wobbling forward and backward (axially) about a 1/2". Then today my cousin and I looked at it and he was watching as a started it and noticed that the pulley is warped. Enough that it's beginning to rub the fan housing. Is all I need to do replace the pulley? (I'm a total Porsche noob, first 911)
1985 Porsche 911 Carrera Front Pulley warped. - YouTube |
Member 911 Anonymous
Oh my Brother,
Your pulley bolt is loose, ask me how I know. It may have also compromised your crank shaft seal and/or worse the #8 bearing seal. Here is my write up: Crankshaft Seal Club, just joined :-o fix on page 4 ![]() ![]() I feel your pain :-( You may get lucky and just need to be torqued down. Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 10-30-2012 at 04:28 PM.. |
Welcome BTW, also it is the "rear" pulley :-(
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Actually, you didn't say specifically whether it was the pulley on the crankshaft (double pulley for A/C belt), or the fan pulley. The former is just as Draco describes, while the latter is a two-piece affair, with the outer half being much thinner and far less solid than the cast crankshaft pulley. It is secured with thin spacer washers and the fan nut on the end alternator shaft, and to my mind far more likely to come undone and wobble than the stout lower pulley would be to warp. Just a thought.
Video shows the double pulley, it is pretty bad
Oooh scheiser, I totally missed the video link. Arrgh, das ist nicht sehr gut!
So a partial engine drop is required yes? Because that pulley is probably shot to **** by now? Especially after I just got done driving it over 1200 miles from Texas to NC.
When doing the engine drop do I really need to do all of the following?: Disconnect Battery Remove Fuel Pump Relay Empty Oil from Engine Sump Empty Oil from Oil Tank Raise Car on Jack Stands Disconnect Hard Oil Line Disconnect & Remove Rubber Oil Line Disconnect Clutch Cable, Arm, and Helper Spring Assembly Disconnect Starter Solenoid Electrical Connections Disconnect Reverse Backup Switch from Transmission Disconnect Heater Hoses From Heat Exchangers Disconnect and Remove Shift Coupler Disconnect A/C Compressor and Tie to Side of Car Disconnect all Fuel Lines Disconnect Main Engine Wire Harness Disconnect Breather Hoses Disconnect Accelerator Linkage Bar Disconnect Cruise Control Cable Disconnect Oxygen Sensor Remove Four Nuts that Hold Engine to Tranny Remove Engine Motor Mount Bolts Lower Engine Down Pull Engine Away from Transmission Lower Down onto Cart and Remove |
French Import
You probably don't need to separate the engine from the transmission, just loosen the transmission mounts.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Disconnecting the battery, is always a good idea. There is that fuse box in the engine bay that loves errand tools touching it. But up to you Brother.
Just disconnect the shift coupler as not to damage it and the shirt rod into the trans. Honestly I did not disconnect it the second time around be I only went down 2-3". But if you jack slips it is history. Just take you time, no need to rush this job. J
I would just do this for a partial drop/lowering:
Disconnect Battery Raise Car on Jack Stands Disconnect Shift Coupler Remove Bumper & Muffller Disconnect A/C Compressor and Tie to Side of Car Remove Engine Motor Mount Bolts and cross member Lower Engine Down on 2-4 inches NO MORE!
French Import
Not needed, 2-4" has very little angle to the trans mounts from what I observed.
Removing the bumper and muffler actually gave me plenty of room even to hand grind down the mushroom pulley mount.
French Import
Good to know, thanks!
If the engine was worked on previously and the crank pulley removed there is a good chance the pulley screw wasn't properly re-tightened. Some of the commonly used references specify too low a tightening torque for this screw. From another thread:
"In most of the early 911's prior to 1978 the crankshaft pulley screw was a M12x 1.5 x 22 mm long hex head plated cap screw of strength class 8.8 (PN 900.083.001.02) and it was used with a 12mm spring or wave washer (PN 900.028.014.01). This screw could only be tightened to 80 Nm or 59 ft-lbs due to it's strength class. This combination was used for both A/C and non-A/C equipped engines. A spring or wave washer is almost worthless as a fastener locking appliance so it is interesting to note that in the mid-year Turbo's and Carreras with A/C that the pulley screw changed to PN 999.093.005.02 (also M12x 1.5 x 22). This screw is of the "Durlok" form (http://www.franciskirk.com/screws.html) and is of strength class 12.9; this screw is tightened to 170 Nm or 125 ft-lbs (which is higher than a normal plated class 12.9 screw tightening torques of 140 Nm or 103 ft-lbs) due to the Durlok locking features consuming some of the tightening torque. A spring washer was not shown being used with this screw. Beginning in 1978 the spring washers were not being used on any of the pulleys but the pulley screw for all cars (through 1989) was the 999.093.005.02 part number. If you received a Porsche part number screw 999.093.005.02 you have the correct part. The head likely has the number 12.9 embossed on it and under the head there may be serrations. A wave washer is not used with this type of screw. The extra number (22) in Wayne's book is the screw's length in mm. All of the pulley screws were 22 mm long (length is measured from the bottom of the head to the tip of the thread). Tighten to 125 ft-lbs (no lubricant on the threads). Jim |
No worries, you will not be lowering enough to affect it. with the bumper and muffler off it should be plenty of room. Lowering it 2-4" just gives you a better view of it.
Just keep on everything as you lower, go slow and make sure it is secure.
So the pulley came off, sheared the bolt. Luckily the seal is unscathed, but I'll replace it anyways. I guess the bolt probably was loose but I had not yet had an opportunity to drop the engine to get to it. Ordering the new bolt, pulley is en route, will fix her up this weekend.
Cool, keep us posted ;-)
Jim, in the picture of the crank in post #2 on this page, is that how clear of a view you had of the crank after removing the muffler and crossmember, etc? Because I'm going to need to drill a hole in what's left of the bolt in the crank to get an extractor on it. So I'm hoping that's how clear of a shot I'll have at it.
Here's a couple pics of how it's looking: The groove that the pulley wore into the fan housing ![]() The pulley: ![]() ![]() Bad view but the crank shaft is smooth on the end, only concern is that the dowel pin might have slightly wallowed out the hole a very minute amount, can't tell yet.
US Army Aviation Black '85 Euro Carrera Last edited by Downtownandy; 11-06-2012 at 01:06 PM.. |
Chain fence eating turbo
I had the crank bolt come loose too because the sorry ass Bentley manual I had, had the bolt torque to about half of what it really needs. I should have known better but I plainly didn't catch it when rebuilding the engine.
Torqued to spec and all is well. No damage to nose of crank or seal occurred. Trust me, this thing was minutes to hours away of flying off the crank if I didn't see it in time.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
| Tags |
| belt , crank , pulley |
