esample's Avatar
One More Track Day?
I have a set of R888s that have about 6 DEs on them. I'm a novice driver, so they have been relatively slow laps. Getting ready to go to Sebring this weekend, I noticed the tires are at the wear indicators and am wondering if I can get another day out of them or should I just go with street tires?
The only other local option I can find today is a set of NT 01s that are 205/50/15 and 225/45/15. Opinions greatly appreciated. BTW, I already know the Toyos have been running too low on pressures. Thanks!
-e.
Black Widow
Blk on Blk '86 911
"...the secret to Porsche: we do things others cannot"
Old 11-09-2012, 06:44 AM
safe's Avatar
Drive them until they are bald.
By the look of them you haven't gotten them up to temperature at all. Drive faster and you will get a lot more grip and better wear.
Magnus
Old 11-09-2012, 06:59 AM
9dreizig's Avatar
Send a message via AIM to 9dreizig
Drive them till they cord!!!! they are just getting fast!
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 11-09-2012, 07:02 AM
Porchcar guy's Avatar
They look fine, just watch them over the track day. Remember, you need to get them hot to work their best and that means scrubbing them in on your out lap, harder braking in a straight line going into a corner and faster outs from the apex on ...Good Luck and have fun !!
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 11-09-2012, 07:05 AM
Jaskas's Avatar
By the looks of the tires it looks that you are running too high pressure. Also it seems that you are not getting the tire warm enough as you drive on the track -> add speed
911-87 mit der 3.6 V-Ram und alles spaß
Old 11-09-2012, 07:11 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Wear indicators like the bars are more indicative of how to look at street tires, in that you need to start thinking about replacing them. Track tires? Meh, they got tons of life left in them. Especially if you don't push them really hard.
The better indicators of "oh boy, I dunno if these are going to last me the day" are the dots in the tread. When those small holes molded in the tread are gone, you can expect cords to be showing real soon.
Kevin L
'86 Carrera "Larry"
Old 11-09-2012, 07:12 AM
esample's Avatar
Thanks guys I appreciate the advice and I'll do just that!
Old 11-09-2012, 07:18 AM
Cory M's Avatar
agree - drive them until they are bald
looks like you might benefit from lowering your pressures a bit, seem like the center is wearing more than the edges..
Old 11-09-2012, 08:19 AM
MBruns for President
JeremyD's Avatar
You have a lot more days on those - they are only just starting to get fast
Old 11-09-2012, 08:32 AM
5:04's Avatar
This, and if you're in the market for R-comps again get NT-01's instead of R888's. I've never hated a tire so much in my life.
that911.tumblr.com
Old 11-09-2012, 08:45 AM
esample's Avatar
Now if I could start to get fast....
Hoping to see you down there tomorrow, Jeremy.
-e.
Black Widow
Blk on Blk '86 911
safe's Avatar
-e.
There is nothing to it, just brake less to carry more speed into the corner and when you hit the apex you floor the right pedal and keep it there.
It looks like the tires hasn't been warm, and then you haven't been near either your or the cars limit.
Aim for around 32 psi when warm.
Magnus
Old 11-09-2012, 09:12 AM
-e..The trick to going fast is to sneak up on it and not get over your head. Watch where the go fast guys brake and try to do the same...watch their line from entry to exit and where they hit the loud pedal on exit. Have fun !!
15 year PCA member
Old 11-09-2012, 10:16 AM
Schleprock
KTL's Avatar
Originally Posted by Porchcar guy View Post
-e..The trick to going fast is to sneak up on it and not get over your head. Watch where the go fast guys brake (in a car similar to yours) and try to do the same...watch their line from entry to exit and where they hit the loud pedal on exit. Have fun !!
I added the bold part because i've watched people come up on say, spec Miatas, and then blow the corner because the Miata brakes way later than we can. They can't brake harder per se', but the nature of that car is that it hardly uses the brakes at all!
Kevin L
'86 Carrera "Larry"
Old 11-09-2012, 10:20 AM
Kevin...thanks for the qualification...I assumed that the drivers/cars would be 911's...my bad :=)
15 year PCA member
Old 11-09-2012, 10:35 AM
JeremyD's Avatar
As Andy Lally said to me and shakinjoe at the bar one evening (showing off his Daytona 24 Rolex) - really not that different from what you guys are doing - we just carry more speed and turn in earlier... that's all.
Old 11-09-2012, 11:20 AM
Hi,
My experience is that your pressure is way to high. (this gives less grip)
We start with cold pressure 1.7 to 1.8 bar front and rear (depends on track temps) and this give 2.1 bar hot...this is the sweet spot.
The shoulder looks new...this means that your can use more speed in the corners...
André
Old 11-09-2012, 12:02 PM
Max Sluiter
Flieger's Avatar
Replace them when they look like this:
Tires and Suspension_ 007 by Max_911S_fahrer, on Flickr
Tires and Suspension_ 005 by Max_911S_fahrer, on Flickr
Yes, those are the same tires next to each other. Advan AO48s.
Old 11-09-2012, 05:35 PM
Wilhelm's Avatar
Flieger; Looks like you got your moneys worth out of those 2 tires
Old 11-09-2012, 08:58 PM
Steve W's Avatar
You cannot drive R888s till they cord!! These are not NT01s. In fact once you hit the last 2/32s of thread, it is a completely different compound with zero grip! BTDT. There is a reason R888s are the most hated tire in the world.
Old 11-10-2012, 12:07 AM
