Diffuser for lead soldering
I've been doing a bit of lead soldering on my restoration. The only diffuser for my torch I've been able to find is from Eastwood. It has a rubber neck on it. Unfortunately, I have burned through the rubber part of two of them. Since I am not interested in burning down my garage, I would like to find a diffuser that is all metal. Anyone have a recommendation and a source?
Steve B.
1972 911t
1999 328is
Old 11-09-2012, 12:51 PM
Charles Freeborn's Avatar
If you're using a propane torch (variety that plumbers use), there are metal clip on diffusers for paint stripping. Available at hardware / paint / home improvement stores.
If you're using a welding type torch, perhaps a "rosebud" torch head will spread the heat in a wider pattern.
-C
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 11-09-2012, 01:35 PM
I am using a acetylene torch without oxygen.
Steve B.
1972 911t
1999 328is
Old 11-09-2012, 03:01 PM
