Diffuser for lead soldering
I've been doing a bit of lead soldering on my restoration. The only diffuser for my torch I've been able to find is from Eastwood. It has a rubber neck on it. Unfortunately, I have burned through the rubber part of two of them. Since I am not interested in burning down my garage, I would like to find a diffuser that is all metal. Anyone have a recommendation and a source?
Steve B. 1972 911t 1999 328is |
If you're using a propane torch (variety that plumbers use), there are metal clip on diffusers for paint stripping. Available at hardware / paint / home improvement stores.
If you're using a welding type torch, perhaps a "rosebud" torch head will spread the heat in a wider pattern. -C
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
I am using a acetylene torch without oxygen.
