Engine shroud refurbishing
I pulled the engine and am in the middle of cleaning, resealing and refurbishing the lot.
Any suggestion to get the engine shroud as new? It's dirty and a bit cracked at the surface. Searched a bit but most threads are about powder coating and blasting. Thanks! Ed ![]() ![]()
72 911E Targa (fun car) BMW 535i Xdrive (work car) Volvo XC90 Ocean Race (family car) VW T2 Riviera Camper van |
shroud
Ed,
Mine looked like yours. I wet-sanded, then used rubbing compound...then a couple of coats of satin clear. PS: I de-greased it 1st...probably using carb cleaner and a tooth brush. ![]() ![]() ![]() ![]() regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ Last edited by al lkosmal; 11-11-2012 at 03:17 PM.. |
No real good ideas here. I "reconditioned" mine but was not doing so in order to keep it looking original. Mine was in worse shape than yours and here's what I did (sorry, I don't have any pics):
- Wash/degrease thoroughly - "Scruffed up" with 120 grit sandpaper - Applied a coat of new fiberglass resin to try to arrest a bunch of cracking - Painted inside flat black and painted outside with black wrinkle paint |
Was typing mine while Al was typing his - I like Al's solution better!
Thanks guys!
Al, how did you refurbish the airhousing? Looks great! Ed
6 cylinder symphony
I'd degrease it and find some high temp green paint and just paint it.
If you don't want to stay stock, there is a carbon fiber shroud out there that I think looks pretty good.
'84 3.2 Targa '89 964 Coupe "What do you mean NEXT project?" - my wife |
Friend of Warren
I would not paint that if you ever have thoughts of selling. Buyers of long hoods want originality.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Al, Yours look great.
Nice job. |
The fan and housing were de-greased and bead blasted.
regards, Al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
