Eddyvdw's Avatar
Engine shroud refurbishing
I pulled the engine and am in the middle of cleaning, resealing and refurbishing the lot.
Any suggestion to get the engine shroud as new? It's dirty and a bit cracked at the surface.
Searched a bit but most threads are about powder coating and blasting.
Thanks!
Ed
72 911E Targa (fun car)
BMW 535i Xdrive (work car)
Volvo XC90 Ocean Race (family car)
VW T2 Riviera Camper van
Old 11-11-2012, 11:59 AM
al lkosmal's Avatar
shroud
Ed,
Mine looked like yours. I wet-sanded, then used rubbing compound...then a couple of coats of satin clear.
PS: I de-greased it 1st...probably using carb cleaner and a tooth brush.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 11-11-2012, 12:38 PM
No real good ideas here. I "reconditioned" mine but was not doing so in order to keep it looking original. Mine was in worse shape than yours and here's what I did (sorry, I don't have any pics):
- Wash/degrease thoroughly
- "Scruffed up" with 120 grit sandpaper
- Applied a coat of new fiberglass resin to try to arrest a bunch of cracking
- Painted inside flat black and painted outside with black wrinkle paint
Old 11-11-2012, 12:42 PM
Was typing mine while Al was typing his - I like Al's solution better!
Old 11-11-2012, 12:43 PM
Eddyvdw's Avatar
Thanks guys!
Al, how did you refurbish the airhousing? Looks great!
Ed
Old 11-11-2012, 12:49 PM
6 cylinder symphony
I'd degrease it and find some high temp green paint and just paint it.
If you don't want to stay stock, there is a carbon fiber shroud out there that I think looks pretty good.
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
Old 11-11-2012, 12:51 PM
Friend of Warren
I would not paint that if you ever have thoughts of selling. Buyers of long hoods want originality.
Kurt V
Old 11-11-2012, 01:36 PM
Al, Yours look great.
Nice job.
Old 11-11-2012, 02:29 PM
al lkosmal's Avatar
The fan and housing were de-greased and bead blasted.
regards,
Al
RGruppe #669
Old 11-11-2012, 03:55 PM
