Banned
MAF sensor need ID
I got this after mark MAF sensor from my friend's 964, but he lost chips, Can I use it on my 3.2? Where can I get new chip? Need you guys help.
PS. THE MAF Sensor is look like lower picture Many thank!! ![]()
Chain fence eating turbo
That looks like the brand Authority IIRC?
I know the 964 AFM is the same as the C3.2 but that is comparing apples to oranges. It should work as long as the chip is for a 3.2.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
It looks a lot like the Autothority unit that I have but the control box is different. I'm guessing Steve Wong could modify a new chip for it. The stock 3.2 ECU chip will work but not very well. Let me know if you want a picture for comparison.
1987 Guards Red Targa, cams, exhaust, MFI intake, lowered, 7 and 8's, 200,000 plus miles of smiles |
Banned
Thanks Tippy and tratza.
Hi tratza, can you post your Autothority MAF picture for me? many thanks! By the way, where can I get Autothority chip? |
Now that I look closer the controller looks the same just a different label. I think AutoThority closed shop. Check with Performance since they used to handle them. Mine is about 20 years old. The only problem I had was about 15 years ago when the potentiometer started giving me problems. Cost only $90 to replace. Very happy with it.
Banned
Hi tratza
Thanks a lot, can I ask where do you replace them? I think I might use them in my 3.2. appreciate! |
Good question. I did a search and didn't come up with anything. I don't think its a part you need to keep in the garage. Mine lasted a long time and it was probably the Texas heat that did it in. I'd check with our host and maybe a garage that has race experience.
