One High Beam Doesn't Work?
Hi there,
Hope Thanksgiving went well for everyone.
I have an issue with my passenger side high beam. I just replaced my turn signal switch (it had burned out long ago). While I was at it, I decided to change my headlights, since the hi beam wasn't working on that same side.
After installation, the low beams worked great, and the switch between low and high beams worked great.
Despite that, however, the high beam on the passenger side still doesn't come on.
Anything come to mind?
Thanks!
1981 911 SC
Old 11-25-2012, 08:58 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Check Fuse Panel to insure the wires going into fuse is secure, sometimes they wiggle out, especially if tampered with in the past.
This happened to me when I installed my relay, did not torque the screw tight enough. :-(
Jim
'85 Carrera Targa
PCA/POC
Old 11-25-2012, 09:12 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Fuse panel.
I agree, have a look at this:
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 11-25-2012, 09:23 AM
Thanks!
Really do appreciate it.
Old 11-25-2012, 09:44 AM
Here is a picture. Am I missing the fuse? Should there be a wire entering there as well?
Old 11-25-2012, 10:04 AM
Missing fuse.
You are missing the right high beam fuse.
Also, compare your fuse values to our '86 fuse panel:
Good luck,
Gerry
pm me as needed.
1986 911 Targa.
Only in L.A.:
Old 11-25-2012, 10:26 AM
RETIRED
Joe Bob's Avatar
That missing fuse is for the passenger high beam, 8 amps.
2012 ML350 3.0 Turbo Diesel
Old 11-25-2012, 10:27 AM
Dumb question:
Does it matter if it's the white or yellow 8 amp?
Old 11-25-2012, 10:37 AM
RETIRED
Joe Bob's Avatar
Not really....8 amp is 8 amp.....best to have a downstream relay system installed to save the stalk for burning out. It's a known SC problem, especially with high wattage H4 installs.
Pelican sells a kit.
Old 11-25-2012, 10:40 AM
Fuse panel.
Fuse values:
1986 911 Targa.
Only in L.A.:
Old 11-25-2012, 01:19 PM
Great. Thank you all very much. You guys are a huge help. Love this forum!
Old 11-25-2012, 03:22 PM
