				Re-Indexing Torsion bar adjustment lever
			Hello,
				Do I need the front end jacked up to be able to Re-Index The Torsion bar adjustment lever? Thanks
	1978 RUF 911SCR  |
			 Member 911 Anonymous
			For the fronts or rears
	'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC  |
			lol...front
	1978 RUF 911SCR  |
			 Go-Kart Mozart
			Yes.
	Even with the adjusting bolts backed all the way out you'll need to lift the front a bit to relieve tension on the adjusters. -J  |
			Well, then Yes. By raising it you can loosen the height adjuster, remove the end cap and position the end cap where you need it to be.
			Any tips on getting it off the torsion bar? Pics or links to other threads? I did do a search but it pretty much was all referring to the rear.
	1978 RUF 911SCR  |
			It depends if rust got in there and hydro locked it.
					BFS should slip it right off but if the cap comes off with the T bar, then just remove it and use a large open end sacrificial wrench and sledge it off. Ask me how I know :-[
