Smoove1010
Basic Leakdown Test Question - Plugs In?
My understanding is that for a compression test, all plugs stay in except on the cylinder being tested. Is this the same for a leakdown test, i.e., plugs out one at a time?
Thanks in advance, GK |
compression test.
For a compression test I take out all plugs. The idea is to rotate the engine as
fast as the starter will allow to attain a maxiimum reading, keep the throttle fully open. This technique is cited in most of the literature. For a leak down test it dosen't matter, but I would take the other plugs out on some engines. An example would be to see if the head is warped. You are just watching for air flow and looking to see where it escapes. As well as looking for total air loss. Anything up to 10 percent is acceptable. To evaluate an engine fully I first do a compression test. Look at the total on each cylinder and if any cylinder is 20 lbs less than any other cylinder pour a little oil into that cylinder. If the compression increases that indicates worn rings. If compression does not improve it could mean worn,leaking valves. This gives you more information of what to look for when you move on to the leak down test. |
During a leak down test never remove a spark plug until the engine is on TDC of the cylinder to be tested. Then remove only that plug. The reason is the way the 911 2-valve head is constructed, and the exhaust valve is directly below the plug. If the plug is removed, when the exhaust valve is open, a good chance exists that a piece of carbon can fall from the tip of the plug and land on the exhaust valve seat. Then, during testing, when the engine is put on TDC for that cylinder, the exhaust valve will close against that very hard chunk of carbon, and not seal against the valve seat. Result? Faulty number.
What is the chance of this happening? Probably pretty slim, but my shop had cars come in "with 40% leakage in cylinder #x" asking for a second opinion. Of course, the car had been driven since the "bad" test at the other shop, and the carbon that was there was gone, so our test came up clean. The benefit? We gained a new customer - every time.
Keep the Shiny Side UP! Pete Z. |
non-whiner
I agree with the above, but will add that you run a risk with all plugs out of dirt getting sucked into the other cylinders. On a 911 engine with the intake plugs angled up, this is a bigger risk than you think. On a compression test, as long as you test all cylinders in the same way your results will be consistent. Also, the gauge captures the compression reading, so engine cranking speed is not as important.
"Too much is just enough." |
Smoove1010
Thank you Mr. Zimmerman for passing that along. Would you care to weigh in on the compression test procedure, i.e., plugs in or out?
For the reason you cite, it seems like it would be best to perform the leakdown first, followed by the compression test. As I recall, the engine has to be at operating temp for both tests to be accurate. I'll have to work fast and wear long sleeves! |
So, could a reliable leakdown test be done on an engine on an engine stand?
white rabbit
So, during the compression test it is mentioned to "disable" the ignition and the fuel system.
What is the best/safest way to accomplish this on a 1988 3.2. Also, do I need an extended reach coupler for the deeply recessed spark plug hole . Enjoyed all the above. Thanks. Don
DRL |
