how to add a turbo
Hi I want to ad a turbo to my 84 targa and I don't know what parts I need to add a turbo 4 to 5p any kit to do it or any one help me with a parts list thanks
Old 12-13-2012, 02:15 AM
Diss Member
Quicksilver's Avatar
The only kit I've heard of is from Promotive. They have a low pressure that kept the DME. I think there might be 2 companies that use that name. I believe they are (or were) in Kentucky or Tennessee.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 12-13-2012, 02:34 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Adding a real turbo involves a multitude of details, just one small one is, how you gonna scavenge the oil out of the low pressure side of the bearings?
You could just use one of these:
JDM Universal Black Turbo Whilsle Exhaust Sound Simulator Bolt on Kit EG6 EM1 | eBay
If you want a turbo, buy one already done at the factory. I have done this and while it is basically a plumbing exercise, without fabrication skills, and lots of detailed info, you can in a flash trash a very expensive engine.
Volumes of books have been written on the subject.
Eric
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 12-13-2012, 07:14 AM
Northern Motorhead
wildcat077's Avatar
Just a little piece of advice ... if you're unsure about all that is involved in converting a N/A engine to a turbo,unless you have somebody with previous knowledge do it for you,it would be like building a ticking time bomb ... lots of $$$ when it blows up !
A safer and more reliable route would be to install a 3.6 !
Just sayin ...
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 12-13-2012, 07:21 AM
Best method to get a turbo in your 911:
Step 1: Sell '84 911
Step 2: Buy a 930
Step 3: Done
The price delta between the two cars will probably be cheaper in the long run than a conversion, plus you get the sexier 930 body, the superior 930 suspension and brakes, better resale than a conversion, AND the engine has already been developed and sorted by the factory.
That said, the 930 appears to be an acquired taste, and time on these forums has convinced me that there are "930 people" and "911 people", and ne'er the twain shall meet.
Old 12-13-2012, 08:02 AM
charlesbahn's Avatar
I did the Protomotive conversion back in 2004, it has been flawless.
Protomotive Pictures
Protomotive Stage ! Install (Part 1)
Old 12-13-2012, 08:03 AM
jsveb's Avatar
Do a search here on pelican, i.e.: turbo conversion. You will find plenty of succefull attempts.
Ask the same question on the turbo side of this forum, and you'll likely get more feedback.
The Carrera 3.2 engine is a really good candidate. You will be able to get about 330-350 chp.
The 87- with the G50 can handle that power. The 915 gearbox needs to be treated a little more careful.
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 12-13-2012, 12:09 PM
twin plugged targa's Avatar
If you are handy with a wrench and have deep pockets and dont mind your 911 reducing in value then go right ahead - many have done it here
However, the more practical and financially sound route would be to sell your '84 (unless you do have deep pockets and can have both!)
Then buy a 930 - either stock if you are SURE you want to keep it stock or if you want ulitmate power then buy someone elsess project which they have sunk $$$$ into.
I have owned:
a stock '86 3.2 Carrera
a stock '70 911T
a modified '71 911T
and a 930
I have loved all of them - and wish I had not sold any of them, however the 930 definately gives more of a rush when I drive her.
I think there is not really a divide between 911 owners and 930 owners
I DO believe there may be a divide between car modifiers and those who believe it is a sacrilege to alter from standard
- My personal advice would not be to modify
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001
1984 Carrera 3.2 IROC RSR look
Old 12-13-2012, 12:22 PM
