Mike80911's Avatar
Removing E bake handle
I did a search but could not find the answer. How do you remove the e brake handle from the car? I removed the auto heat cover unit and removed the 3 bolts holding the e brake assembly to the body but cannot get to the cables to remove the unit. How do I disconnect the cables from the assembly?
Mike
89 930 Cab Black
11 Cayenne
Old 12-16-2012, 09:32 AM
Danny_Ocean's Avatar
Here's a start:
calling ebrake experts
handbrake removal
Old 12-16-2012, 09:55 AM
Registered speed offender
78SCRSMAN's Avatar
The easiest way and likely the only way is to undo the e-brake cables and heater box cables from underneath the car... e-brake cable attachment is behind the rotors, remove the nut and you'll have all the slack you need.
If you keep looking back, you'll never move forward.
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/506621-project-911r-something.html
Old 12-16-2012, 11:10 AM
