Tilikum Turbo's Avatar
HI-Beams continually ON(when turning lights on)...83 911
Does anyone know of an additional relay/switch between the fuse box(Black 5-prong relay) and the steering wheel actuator/stalk for turning on the high beams?
Relay at fuse-box checks out OK, and actuator/stalk contact is not fused together.
Reading the Bently Manual, its described as a 4-pole Headlight Dimmer/Flasher Switch(which is NOT the 3-pole ON-OFF Push-Pull/parking light/headlight Switch)
Thanks for any help!
1983 911 3.3L Turbo(YES, I know the turbo badge is on the right...had to be different!)
1996 Toyota Corolla(der 'clapper')
Old 12-16-2012, 02:55 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Check post #3.
Turn signal fuse blowing
1981 911SC Targa
Old 12-16-2012, 03:28 PM
turn signal switch quick fix pictures
this should fix it
crude rudy
'84 cab
'14 ZX-14R
Old 12-16-2012, 03:33 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Search under WON, he posted the fix and others contributed other things they found
'85 Carrera Targa
PCA/POC
Old 12-16-2012, 03:53 PM
dshepp806's Avatar
Great threads on this. Has certainly bought me time....
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 12-16-2012, 04:52 PM
