transmission questions..
Im toying around with the idea of putting a 993 6 speed trans in my 87 cab.. never seen it done.. any thoughts or advice would be great. thanks
Old 02-04-2016, 03:32 PM
BIG job,............the tunnel needs to be modified as well as the crossmember and the shift rod needs to be shortened. Not for the faint of wallet.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-04-2016, 04:18 PM
Bill Verburg's Avatar
stock 993 gearing is on the tall side
to fit one to an '87 911 the torsion bar tube has to be resected and the suspension converted to coil over w/ all the associated reinforcement of the chassis.
As Steve says, BIG job
If you want an air cooled 6 speed sell the 911 and get a 964 or 993
Bill Verburg
Old 02-04-2016, 04:31 PM
ok.. doesn't sound too bad. what kind of mods have you done to the tunnel? torsion bar tubes an stay put?
Old 02-04-2016, 04:32 PM
mmm.. ok thanks for the input.
Old 02-04-2016, 04:36 PM
Senior Advisor
James Brown's Avatar
torsion tubes, coil over, chassis re-section, linkage.
if that sounds easy, than the swap is a piece of cake! and why do that to a cab? not exactly a race car
08 Cayenne Turbo
Old 02-04-2016, 04:37 PM
gearhead
$12-15k to do it and will take about the same away from the value of the car.
The question I would have is why you want to do it. Usually more than one way to achieve the same end goal.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 02-05-2016, 06:25 AM
I have to say I don't understand these desires, but it is not my car.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 02-05-2016, 07:34 AM
Eng-o-neer
Tremelune's Avatar
How about the same job on a 915 car with a 3.6? Converting to coilover has its own benefit independent of the transmission, and my car is such that I wouldn't mind having the tunnel banged up.
The research I've done usually came upon a 5spd G-50 car, or the project stalled out (presumably for obvious reasons)...
Old 02-05-2016, 12:38 PM
