91133's Avatar
Boxster brake conversion - '73 911
Looking at the Pelican conversion kit and wondering if anyone has experience of installing on a pre-impact 911? Main question - will it fit inside 7&8x15 Fuchs? Thanks.
Old 12-26-2012, 03:32 PM
Bill Verburg's Avatar
perhaps you could elucidate on the reasoning for this?
Bill Verburg
Old 12-26-2012, 03:49 PM
Senior Advisor
James Brown's Avatar
i don't think they will fit under the 15's. the turbo breaks will
08 Cayenne Turbo
Old 12-26-2012, 06:01 PM
They do fit under 15 rims, steel or alloy. That was one of our reasons for developing this kit in the first place.
With 930 brakes, there is a little more work and expense and they will fit under 15" rims too.
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 12-26-2012, 08:26 PM
Senior Advisor
well thats good, good brakes for a "r" car
08 Cayenne Turbo
Old 12-26-2012, 10:08 PM
Hell Belcho
Nostril Cheese's Avatar
it will fit, but its not really something that adds a whole lot over the stock brakes..
Old 12-26-2012, 11:56 PM
91133's Avatar
Thanks for the responses guys. Having to replace splayed Alu "S" calipers and saw this kit was available so the first question before further 'research' was the "will they fit?" one.
Interested by the last comment that the Boxster brakes would offer no better performance - on paper, they should be much better than on a standard F series S?
Old 12-27-2012, 03:10 PM
It depends on what you mean by better
if you just do the fronts you get ~25% more brake torque in front, but nothing has changed in back so bias goes much more to the front, is that what you want?
If the S was fine then why not replace w/ S or A
If you are overheating the brakes then maybe wide A fronts would do it for you w/o mucking up bias, in a light car like yours that's very likely the most you would want to do.
Bill Verburg
Old 12-27-2012, 03:23 PM
91133's Avatar
Fair points, Bill.
Looking at a 4 wheel replacement (with appropriate master cylinder) so anticipated balance would be less of an issue and certainly compensable with valving (which we can model on the computer).
"Better" is in terms of track days 5 or 6 times a year. Road performance is less critical and running softer pads off the track.
Old 12-27-2012, 03:31 PM
Max Sluiter
Flieger's Avatar
Road performance is probably more critical if you ask me- as in you don't know when you might have to make a sudden stop in the rain. On the track things are usually much more predictable.
Old 12-27-2012, 03:42 PM
Fair points, Bill.
Let me further point out that brakes stop the tire but the tire stops the car.
It seems to me that unless you have some special situation that I've ever run into that a '73 just doesn't need much if any brake upgrades.
I've never seen one that needed more than wide As in the front
The Boxster upgrades use the same 3.2 Carrera rotors that the wide A's use so yes, you get a torque upgrade but that isn't really needed or usable over and above what the stock brakes provide.
BBK's are desirable in 2 cases
1) where stock brakes experience temperature rises that can not be controlled otherwise
2) where bigger stickier rubber is utilized that can transfer the increased torque effectively to the pavement
Bill Verburg
Old 12-27-2012, 04:37 PM
