markmalin's Avatar
First valve adjustment - have some questions! ;)
Hi guys,
This is the first time I've done this on a 911. I have an 85 Carrera. I removed the valve covers and the gaskets are sort of an orange rubber stuff... are these silicone gaskets, and if so can I just re-use them rather than put the ones on that i bought from our host? The car was not leaking at all...so these seemed to be working well.
If I can re-use them...what do I need to do to prepare them?
Second.... Do I have to use brand new ny-lock nuts, or is it OK to reuse the old ones?
Thanks!
Mark.
Mark - New Glarus, WI
Old 12-28-2012, 09:05 AM
Recreational Mechanic
Nickshu's Avatar
I would use new gaskets and new nuts. Noone wants to do this twice.
I tried re-using silicone gaskets on my SC, they didn't leak before but did leak after reinstall, not alot but somewhat. Others on the forum have re-used them without leaks....better lucky than good I guess.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 12-28-2012, 09:21 AM
Red Line Service
Marc Bixen's Avatar
With those questions maybe you shouldn't have removed the V.C.'s at all.
ALWAYS replace the gaskets, nuts, and Aluminum washers. I see you do have a new kit on the bench, good thinking and good luck. And you've been well advised on the Kendall gear lube, you'll like it.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 12-28-2012, 09:23 AM
mikeferg75's Avatar
Those appear to be the Silicone type you can reuse, I have them as well, they work nicely.
I would use the new locknuts from your kit though.
Ferg
1975 Carrera Coupe #391
1980 924 11k orig miles
1974 914 2.0 LE Creamsicle
1979 Dodge Lil Red Express
2015 Wrangler Unlimited, and a bunch of bicycles.
Old 12-28-2012, 09:32 AM
markmalin's Avatar
I'll use the new gaskets then.
So...another question - the Bentley's manual says there is a "Z1 mark" on the crank case pulley. I see 3 different notches on the cc pulley at different locations on the pulley. 2 close to each other, one further away. One of these lines up correctly when the distributor rotor is aligned with the "1" mark. My question is.... I don't see any sort of "label" on the crank case pulley like they show in the books. What I do see is what looks like a weight or something attached at the point of where "Z1" is stamped in the books. Cylinder 1's intake valve rocker looks up all the way. Can I be certain this is truly TDC? Perhaps Carrera's don't have the text "Z1" stamped on the pulley?
Mark.
Old 12-28-2012, 09:37 AM
markmalin's Avatar
Not sure what you mean by this statement - I felt these were honest questions. Our host sells silicone gaskets that they say can be re-used ("you don't have to keep buying new gaskets"). If these are that type, I want to know if it is advised to re-use them or use the new non-silicone ones I bought. As I said this is my first attempt at valve adjustment on a 911...I've done BMW's many times. This is a different beast - hence the post.
Mark
Old 12-28-2012, 09:42 AM
French Import
zippy_gg's Avatar
Wouldn't that make it extremely difficult to adjust the valves...(see title of the post)?
Besides, it is by trying and asking questions that we learn.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 12-28-2012, 09:46 AM
Mark.
You need to see which cylinder your rotor is pointing at. I think at Z1, it should be number 1. Some one please correct me if I am mistaken.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 12-28-2012, 10:17 AM
