First valve adjustment - have some questions! ;)
Hi guys,
This is the first time I've done this on a 911. I have an 85 Carrera. I removed the valve covers and the gaskets are sort of an orange rubber stuff... are these silicone gaskets, and if so can I just re-use them rather than put the ones on that i bought from our host? The car was not leaking at all...so these seemed to be working well. If I can re-use them...what do I need to do to prepare them? Second.... Do I have to use brand new ny-lock nuts, or is it OK to reuse the old ones? Thanks! Mark.
Mark - New Glarus, WI |
Recreational Mechanic
I would use new gaskets and new nuts. Noone wants to do this twice.
I tried re-using silicone gaskets on my SC, they didn't leak before but did leak after reinstall, not alot but somewhat. Others on the forum have re-used them without leaks....better lucky than good I guess.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
Red Line Service
With those questions maybe you shouldn't have removed the V.C.'s at all.
ALWAYS replace the gaskets, nuts, and Aluminum washers. I see you do have a new kit on the bench, good thinking and good luck. And you've been well advised on the Kendall gear lube, you'll like it.
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
Those appear to be the Silicone type you can reuse, I have them as well, they work nicely.
I would use the new locknuts from your kit though. Ferg
1975 Carrera Coupe #391 1980 924 11k orig miles 1974 914 2.0 LE Creamsicle 1979 Dodge Lil Red Express 2015 Wrangler Unlimited, and a bunch of bicycles. |
I'll use the new gaskets then.
So...another question - the Bentley's manual says there is a "Z1 mark" on the crank case pulley. I see 3 different notches on the cc pulley at different locations on the pulley. 2 close to each other, one further away. One of these lines up correctly when the distributor rotor is aligned with the "1" mark. My question is.... I don't see any sort of "label" on the crank case pulley like they show in the books. What I do see is what looks like a weight or something attached at the point of where "Z1" is stamped in the books. Cylinder 1's intake valve rocker looks up all the way. Can I be certain this is truly TDC? Perhaps Carrera's don't have the text "Z1" stamped on the pulley? Mark.
Mark
French Import
![]() Besides, it is by trying and asking questions that we learn.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
