kent olsen's Avatar
Heat and defrost with headers
I'm going to put this out again.
My 72 doesn't get driven much in the Oregon winters because with the racing headers I have no heat or defrost.
I've tried:
1. Heat exchanger from a small sport airplane. Looked good but I have a twin plug distributor and the tin behind is modified and prevents good air flow to the heat exchanger on the left side.
2. Marine 12 volt heater but it requires at least an alternator with 50 amp capacity and mine isn't.
3. Any other 12 volt heater is really questionable with the exception possibly of hard wiring and a larger fuse.
4. Moving to Florida but I did that once and moved back to Oregon.
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 12-23-2012, 04:41 PM
Senior Advisor
James Brown's Avatar
did you look into the wabasco fuel heaters?
08 Cayenne Turbo
Old 12-23-2012, 05:15 PM
Recreational Mechanic
Nickshu's Avatar
Hi Kent. Wish I had a good answer for you but last summer I want thru McMinnville and went to the aircraft museum there..wow what a place! I lived in DC for 7 years and that museum there puts the Smithsonian to shame!
Cheers
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 12-23-2012, 05:16 PM
esonefour's Avatar
I've seen small 12v hair dryer elements used in race 911's.
I also run headers and was thinking maybe a alloy pipe from chassis to chassis hole at the rear and the engine heat would dissipate the pipe, have one end on the fan and the other to the screen?
Like an intercooler well heat exchanger.
Or just run with the windows down and wrap up warm
Old 12-23-2012, 06:22 PM
ROW '78 911 Targa
timmy2's Avatar
+1 Wabasto heater sounds like your best option. wabasco may be spicier though...
Webasto – Auxiliary Heaters for Cars
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 12-23-2012, 06:34 PM
Senior Advisor
I wike webasco on weverything
08 Cayenne Turbo
Old 12-23-2012, 06:51 PM
ROW '78 911 Targa
timmy2's Avatar
LOL...wee twoo
Actually after looking at the Webasto heaters, SSI's would be cheaper.
Dennis
Old 12-23-2012, 07:14 PM
kent olsen's Avatar
An electric blanket even sounds good if you could find a 12 volt one.
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 12-25-2012, 12:20 PM
Your wish is my Command, Sire:
12 Volt Heated Travel Blanket | Electric Space Heaters| Northern Tool + Equipment
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-25-2012, 12:45 PM
GaryR's Avatar
Send a message via ICQ to GaryR
Heated jacket and pants, my buddy with a Lotus 7 replica swears by them!
http://cozywinters.com/heated-clothing/?source=go&gclid=COuCj-i5trQCFUid4AodAyIAUw
Gary R.
Old 12-25-2012, 01:00 PM
Eng-o-neer
Tremelune's Avatar
I'm thinking about doing this myself:
Modern Eberspacher heater installation
Old 12-25-2012, 03:33 PM
proffighter's Avatar
That's what I did, Eberspächer gas heater installation:
Gas heater installation
Roland
930 Turbo '81 Too many modifications to list
Old 12-25-2012, 05:24 PM
Air Cooled
Craig_D's Avatar
Would you lose any power going with SSI's?
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 12-25-2012, 10:30 PM
Not with a stock 3.0 or smaller engine,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-25-2012, 11:27 PM
Fit a heated front screen & wear a thick coat ...
Andy
M&W 904 ... now gone
GT-style 356C ... also gone
Old 12-26-2012, 03:42 AM
gumba's Avatar
I'd dump the headers and install SSI's. I doubt you'll lose much if any h.p. I friend has a 3.4 efi street motor putting 345 crank h.p. with SSI's. The motor started to lose some power above 6,000 rpm. I run SSI's on my 3.5 turbo motor at 425 crank h.p. I may lose a few h.p. at the top but not enough to warrant running with no heat.
I've tried all the methods mentioned above, plus trying to make heater boxes in a effort to get heat into my '68 VW Crewcab, non of them worked. Or they put out so little heat it wasn't worth it. I finally installed a Smith gas heater.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 12-26-2012, 05:07 AM
kent olsen's Avatar
Thanks everyone for your replys. As my winter projects are whitalled down I'll get to this heat situation and have to make a decision. The little gas heater doesn't look like such a bad idea and since I'm so paranoid about weight, 10 lbs I think I can justify.
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 12-26-2012, 05:25 PM
non-whiner
mreid's Avatar
Put in seat heaters and wear driving gloves. Your butt stays warm and you look cool. Win-win.
"Too much is just enough."
Old 12-26-2012, 07:07 PM
Administrator
Jack Olsen's Avatar
The gas heaters are pretty expensive. I think SSIs are the most cost-effective way to do this. Although fabricating a new heat exchanger box doesn't seem that complicated, and you'd really only need one.
These after-the-fact threads should be required reading whenever someone considers plain headers for these cars. Because sooner or later, it seems like everybody gets tired of being cold.
993 short headers are a second-hand bargain, if you can get them to work with your application.
Old 12-27-2012, 03:16 PM
kent olsen's Avatar
Part of my problem with heat exchangers is I have a twin plug distributor and the tin behind it has been modified (moved forward away from the distributor) which restricts the flow of air out and down to the heat exchanger.
Someone suggested a small heat exchanger on the right side which seems like and idea. I haven't looked to see how the plumbing would work though.
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 12-27-2012, 03:23 PM
