Question Replacing oil line from 911 engine with Aeroquip
Hi all,
I was cruising the technical articles just now and noticed that sombody had replaced the engine oil line on a 911 with Aeroquip type fittings and braided stainless steel lines.
I am backdating my exhaust system, so I need to replace my oil lines and would like to do them this way instead of going with the factory setup (I need to mate a SC engine to a '72 oil tank setup).
Here is a picture from the article:
http://www.pelicanparts.com/techarticles/911_oil_return_tube/911_oil_return_tube_ pic8_big.JPG
Can anybody share more information about this with me? For example: What size braided lines are used (AN-12?)? Where can I buy the adapter fitting between the engine case threads and the AN fitting?
Thanks in advance for any info you can share.
Thanks,
Charlie
[This message has been edited by cds72911 (edited 08-17-2001).]
Old 08-17-2001, 09:53 AM
addictionMS's Avatar
Post
I have done this, and now undone it and relocated the oil tank to the front, but... you need to get the adapters from a comapany called CAT Inc.
You need to get the adapters for the engine case and the oil tank, and yes most people run AN-12, unless you relocate the oiltank to the front, then you need AN-16 for the pressure side and AN-20 for the scavange side. Plus you can also consider Earls hose ends....
Old 08-17-2001, 10:28 AM
Bill Verburg's Avatar
Post
At least use the factory supply line to the pump, #33 in the pic
A good source for lines, fittings and info is
http://www.bakerprecision.com/adapt20.htm
You want to use -12 or larger, -10 is ~9/16 ID, -12 is ~11/16 ID, -16 is ~7/8" ID
Bill Verburg
My Home Page My Pelican Gallery page My Porsche Owners Gallery Page
Old 08-17-2001, 10:42 AM
Pillow's Avatar
Post
I would advise AN-16 or AN-20. AN-12 is essentailly only .5" which is way to small for the volume of oil needed to pass through.
Adrian Pillow
1979 911 SC
1966 VW Microbus
PCA - Peachstate Region
Old 08-17-2001, 10:43 AM
Post
Anyone have a #33 for sale? The one on my '72 had the oil line swaged directly to it (and it went with the engine). I need one of the ones with a removable (threaded) fitting on the end.
Wow, what a great resource BAT, Inc is. They even have a free downloadable guide "Oil Cooling for Porsche". They have everything necessary and some great information too. Thanks!!!
If I read it correctly they recommend AN-12 unless it is for all out racing, a highly modified engine or a turbo (then they suggest AN-16 or AN-20).
Thanks,
Charlie
Old 08-17-2001, 10:49 AM
Post
Adrian check this link, its in the site I recommended above;
http://www.bakerprecision.com/earls1.htm
Bill Verburg
Old 08-17-2001, 11:18 AM
DEL DEL is offline
Post
This crossed my mind also when I saw that a Carrera upgraded oil cooler kit was over $1000. I thought of getting an aircraft style oil cooler and plumbing it with AN braided line & fittings.
Dave Loney
1982 911 SC Targa
1986 Buick T-Type 10.43 @ 129
Old 08-17-2001, 10:42 PM
