SUNROOF Help Needed! Stuck in open position!
My sunroof has suddenly stopped working in the fully retracted position.
It was working fine but when I pushed the button to close it nothing happened, no movement or sound at all coming from the sunroof. I have checked the fuses and the switch looks ok. Is there anything else I should be checking? Has anyone experienced the same problem? |
Sounds like the motor has packed in. Isnīt there a crank in the tool kit for such emergencies?
Location: Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
'88 Carrera
Problem solved
All fixed! Thanks for your replies.
I took the headliner cover off and played around with the wire conections and all works fine now, must have been a loose wire. |
