SUNROOF Help Needed! Stuck in open position!
My sunroof has suddenly stopped working in the fully retracted position.
It was working fine but when I pushed the button to close it nothing happened, no movement or sound at all coming from the sunroof.
I have checked the fuses and the switch looks ok.
Is there anything else I should be checking?
Has anyone experienced the same problem?
Old 01-02-2013, 09:30 PM
twistoffat's Avatar
Sounds like the motor has packed in. Isnīt there a crank in the tool kit for such emergencies?
Old 01-02-2013, 10:27 PM
bdisco's Avatar
Location: Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
Pelican Technical Article: Sunroof Repair - 911 (1965-89) - 930 Turbo (1975-89)
'88 Carrera
Old 01-03-2013, 04:16 AM
Problem solved
All fixed! Thanks for your replies.
I took the headliner cover off and played around with the wire conections and all works fine now, must have been a loose wire.
Old 01-04-2013, 11:38 AM
