What's the purpose of this? Mine was missing...
Did an oil change today and replaced the washer on the oil pressure relief piston on the bottom of the engine at the same time (it was leaking a bunch as a previous owner way over torqued it and smooshed the washer beyond it's sealing threshold....)
The sleeve is missing from mine. (I had the spring and piston fall out) 930-107-533-01-M100 Oil Pressure Relief Sleeve, 911/911 Turbo (1978-89) Any idea what the sleeve does? The other relief piston mounted horizontally doesn't have one, at least according to the detail I saw. It's only a $7 dollar part. Can it wait till the next oil change?
'87 911 Carrera Coupe (go fast, small parts / small kids hauler) '04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius") Last edited by chrisbruck; 01-03-2013 at 12:01 PM.. |
I think that sleeve is a support for the spring.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Great, add that to my next Pelican order.....
Any reason why the one mounted horizontally doesn't require one?
'87 911 Carrera Coupe (go fast, small parts / small kids hauler) '04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius") |
Shorter spring.
sudo apt-get purge 930
I've never heard of this. Can someone post a picture of it installed so I can see what you're talking about?
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Banned
Ultimate Oil Pressure Relief Valve Thread |
