dcarlson's Avatar
Oxygen Sensor Relay location?
can someone tell me where I find it on my '86 911? thanks
'86 944
'86 911
07 cayman
Old 01-06-2013, 05:13 PM
howard freeman's Avatar
It is in the DME relay,terminal 87 b,located under the drivers seat next to the DME unit. Its held in place by a 10 mm nut.
Howard
Howard Freeman
80 911 SC & 74 914 1.8
79 930 & 83 SC coupe,03 996 TT,02 996 C4
03 X/5 3.0. 370,186 miles now Sons daily driver
10 X5 3.0I 224,515 miles
Old 01-06-2013, 05:22 PM
dcarlson's Avatar
thanks - I was under driver's seat 2 weeks ago - changed out the DME relay - I don't think I saw any other relay. Do you mean it is handled by the DME relay or is it a separate relay? confused...
'86 944
'86 911
07 cayman
Old 01-06-2013, 05:41 PM
The cell in the oxygen sensor (rich lean voltage) goes directly into the DME. The heater for the oxygen sensor comes on with the fuel pump (un-fused).
Rick
88 Cab
Old 01-06-2013, 08:10 PM
The o2 sensor heater is handled by the DME relay terminal 87B.
Howard
Howard Freeman
Old 01-07-2013, 08:07 AM
dcarlson's Avatar
ok guys thanks - didn't think there was separate relay for it. OK, moving on to the next possibility. Un-heated garage limiting my wrenching.. January thaw should be coming...
'86 944
'86 911
07 cayman
Old 01-07-2013, 02:05 PM
French Import
zippy_gg's Avatar
Cylinder Head Temp Sensor needs updating to 2 wire type?
Good write up here: Pelican Technical Article: Cylinder Head Temperature Sensor - Upgrade for 84-89 Carrera
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 01-07-2013, 02:14 PM
What function do you think the Oxygen sensor relay is not doing?
You aren't coming from an Audi Lamda CIS system are you?
Rick
88 Cab
Old 01-07-2013, 04:16 PM
dcarlson's Avatar
no audi lamba CIS. No, been going through a checklist troubleshooting a rough idle and missing/stumbling on acceleration. Still got to do plugs and fuel filter. Did rotor, cap, wires, DME relay.. Don't see any loose wires or vac hoses. 50's end of week may let me finish basic tune-up stuff.
'86 944
'86 911
07 cayman
Old 01-08-2013, 01:31 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Ckt
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 01-08-2013, 01:40 PM
dcarlson's Avatar
ok - DME, wires, fuel filter, cap, rotor, - no change; still won't fire properly on acceleration - after I do plugs the last resort will be the Italian tuneup..
'86 944
'86 911
07 cayman
Old 01-18-2013, 04:14 PM
