frankc's Avatar
Hi Vern,
Which brand of rotors are those? I like the finish/plating on them.
'73 911T RoW (Project)
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 06-20-2015, 07:16 AM
PMB Performance
Eric_Shea's Avatar
Originally Posted by 911euro View Post
Quick embarrassing question: the rear caliper has 2 19'' bolts to the hub, my question is: there is very little space to put in big wrench to remove it. Is there a trick or a special wrench to remove this lower bolt? I just rebuilt the fronts and now I need to rebuild the rears because after releasing the hand brakes, the brake light on the dashboard is still lid up and it makes squeaky noise. I took a peek at the pistons earlier, they look to be rusted on the exposed portion.
Thx
On the rear of the 911 the handbrake cable has a plastic attachment to the control arm. Take a 10 mm wrench and remove that and then put your socket through the hole in the control arm to reach the lower bolt on the caliper.
Eric Shea - PMB Performance
855-STOP-101
We Restore Vintage Calipers
www.pmbperformance.com
Old 06-20-2015, 09:14 AM
rokemester's Avatar
Never feel embarrassed to ask a question in this forum. I had a tough time removing those nuts as well! I actually trapped a socket wrench trying to remove them and had to leave the scene to gather myself and figure out what to do. As usual Eric has a great tip to avoid this stick point.
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 06-20-2015, 03:55 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Calipers.
When I did the brakes/rotors on our '86, I sent the calipers to a local machine shop
who broke them down & rebuilt them for about $85 each.
I though it was money well spent.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 06-20-2015, 05:05 PM
frankc's Avatar
Hi Eric,
As I'm sure you know, the plastic piece that you mention is only on the steel trailing arms (that I have seen). The aluminum arms have a hole cast in the arm itself for capturing the handbrake cable. I only mention this because the OP stated he had an 1985 Carrera (aluminum TA).
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 06-21-2015, 09:23 PM
PMB Performance
Eric_Shea's Avatar
Gerry
It is, if they replated them.
99.9% of caliper failures are cause by rust... "inside the bore". After roughly 20-30 years, the zinc plating wears off the inside of the bore and, brake fluid being hygroscopic, it attracts water which likes to gather by the rubber seals, of course, right where the wears marks are. This causes rust and causes your pistons to stick.
This is what we always advise people to "NEVER" hone the bores and "ALWAYS" replate the calipers using the factory zinc (not cad).
Otherwise... They'll be sticking again in two years.
855-STOP-101
Old 06-22-2015, 06:21 AM
Originally Posted by frankc View Post
Hi Vern,
Those are pre-painted Zimmerman rotors. I believe it's about $10 more to get them pre painted but I think it was worth it - no rust. Purchased thru Pelican.
Old 06-22-2015, 10:22 PM
Brew Master
cabmandone's Avatar
I guess this puts me "on the clock"
Old 06-23-2015, 05:03 AM
