3.2 charging problem
it started 2 months ago when my car was cranking over fine but wouldn't start. then my oil pressure sender stopped working. One day the cars battery seemed to be draining and every time the car sat for a lithe bit the starter got progressively less powerful until it wouldn't work any more, unless i push started it. The battery light comes on at 850 rpm and flashes then once i step on the gas the light goes away. Ive had the battery tested and its perfect. It reads out to 12.3 volts with the car off. I replaced the alternator myself 6 months ago and it worked beautifully for a long time. Just a side note, when you step on the gas with the lights on they get brighter, so i guess its charging. Any ideas???
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Voltage Regulator.
Here's a hint: ![]() Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
then why does my battery also go dead sometimes?
hook up a voltage sensor while you drive around. if the VR is bad, it will bounce around like crazy, even going up to 16 or 17. I had 2 go bad in a relatively short time period
1982 911 SC 3.0L |
Vr
A bad VR will cook a battery.
Replace with a regulator from our host if required.
Lights
Intermittent light brightness is a huge hint.
RETIRED
Bouncing tach.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Thread Tools | |
Rate This Thread | |
