French Import
zippy_gg's Avatar
Correct Washer for Trailing Arm to Body
A few of my bolts and washers got mixed up during cleaning and I need to know if this is the correct washer to go on the trailing arm bolt that connects to the body on my 86 cab. The inner diameter is correct for the bolt, and the outer diameter is larger than all other washers and would fit in that location. I replaced the old rubber bushings with ER sealed mono-balls.
The illustration and description on the PET does not help...
Does anyone know? Thanks! (the ruler is in inches, not centimeters)
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 01-11-2013, 05:00 PM
frankc's Avatar
I am in a similar situation. Did you ever determine the correct location for this washer?
'73 911T RoW (Project)
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 03-11-2015, 08:54 AM
Smoove1010
Smoove1010's Avatar
If you're referring to item 5 in this diagram from PET, (87 Carrera Trailing Arm - Am I Missing Parts?) my '87 doesn't have any washer there at all, and a couple of fellow Pelicans confirmed that theirs had none either. Not sure if that helps you or just confuses the issue... Could that washer be the one that holds the bottom of the shock absorber to the trailing arm?
GK
1987 3.2 911 Cabriolet
Grand Prix White Exterior
Five Shades of Burgundy Interior
Old 03-11-2015, 10:57 AM
French Import
zippy_gg's Avatar
Yes, I did install a washer per trailing arm, on the nut side. This was for my 86. Not sure if 87 and later were different...
Gilles & Kathy
Old 03-11-2015, 03:28 PM
