Czar of C.R.A.P.
dfink's Avatar
windshield caved in doing 110
SCCA Time trial my lexan windshield caved in on me. Gets your attention.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 10-30-2012, 11:45 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Whoa
'85 Carrera Targa
PCA/POC
Old 10-30-2012, 12:06 PM
OsoMoore's Avatar
At 24 seconds in the video - did you have it sealed properly? I'm glad it didn't lead to disaster.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 10-30-2012, 12:27 PM
Flat Six
Flat Six's Avatar
Holy cr@p!! Bet that got your attention!
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 10-30-2012, 12:28 PM
Grady Clay's Avatar
Perhaps this may tell you why Porsche uses a standard glass windshield (or even a thin glass version).
I have been 220+ mph twice a lap for 12 and 24 hours (935K3) and never a failure.
Let’s see:
Weight savings from a Lexan windshield – a few milliseconds per lap.
Time spent replacing Lexan windshield – down several laps.
Time gained from seeing where you are going (at only 110 mph) – priceless.
Enough said.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 10-30-2012, 03:11 PM
Racer
winders's Avatar
Grady,
All that needs to be done is to use the appropriate thickness (read 1/4") polycarbonate windshield. That thing looked way too thin.
Scott
Old 10-30-2012, 03:19 PM
Grady Clay's Avatar
Scott,
I guess above I was being a bit scurrilous.
My point should have been that the best vision possible makes for the fastest lap times.
I’m probably a ‘poster boy’ for vision vs. lap times.
With my former myopia, I worked hard for the best vision possible while racing (in the ‘60s, ‘70s & ‘80s).
Only recently with cornea implants have I realized how much better vision I could have had and how much faster (and safer) I could have driven.
Sorta the difference between a 935 brute and a 997Cup.
So … my recommendation is to have the best vision possible – a few grams of weight be damned.
Best,
Grady
Old 10-30-2012, 03:44 PM
Non Compos Mentis
One of the fast guys around here couldn't stand the distortion caused by the Lexan windshield flexing at speed.
Went back to glass.
Old 10-30-2012, 03:54 PM
Czar of C.R.A.P.
dfink's Avatar
I am pretty sure the issue on this was of my own doing. I used a new window seal and forgot to put a cord in to serve as a lock. Normally there is a metal lock piece "trim" that helps lock the window in. A piece of rubber cord normally used to hold window screen in will work as well. I forgot that step. The winshield didn't cave in as much as the rubber turned in because it wasn't expanded and locked. That then allowed the lexan to flex in.
66 912 Coupe
Old 01-29-2013, 04:32 AM
redstrosekNic's Avatar
Whoa!
Dustin
Old 01-29-2013, 05:19 AM
Kind of Blue
MrBonus's Avatar
Finally, a pragmatic solution to our temperamental and poorly-functioning air conditioning systems.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel)
2024 Ford Bronco Raptor
Old 01-29-2013, 05:33 AM
redturbo911's Avatar
Wow thats crazy. Good thing you kept cool. Glad it worked out for you and nothing major happened.
Tony
91 964 c2 black/ Work in progress/Finally back on the road
85 EURO 930 Black slightly moded slowly reviving her
77 911tt EFI wide body red/ Slightly modified SOLD
Old 01-29-2013, 06:08 AM
dgmark's Avatar
After replacing 2 glass windshields in two years I switched to lexan, no problums if its installed correctly and cleaned properly
30 Year ASE Master Certified Technician
1986 911
Old 01-29-2013, 06:20 AM
Lucky it did not back into your face, or throat area...
at 110 mph.
Old 01-29-2013, 06:23 AM
wayner's Avatar
Search youTube for "miata crash"
Mid way through the video a guy loses his steering wheel.
Aside from this and that incident, you guys amaze me with your composure when things go wrong. I might have jumped out ;-)
Old 01-29-2013, 07:32 AM
Quantum Mechanic
mpetry's Avatar
Send a message via Yahoo to mpetry Send a message via Skype™ to mpetry
I've got a video of a tire failure on the banking at Daytona - doing about 160 in a GT3 Cup. The car spins around and the windshield blows out - it is like a bomb going off. Not sure if my website will stream it but here is.
http://petry.org/markp/DaytonaGT3RS.wmv
Not something I'd like to have happen to me. Might need a new driver's seat as well.
Mark Petry
Bainbridge Island, WA
81 SC
Old 01-29-2013, 08:12 AM
Deadeye's Avatar
Did you have any clips installed? I have 6 aluminum clips that prevent this kind of blow out.
Old 01-29-2013, 02:06 PM
bavaria911's Avatar
Did you ever think of a safety issue there?
Bavaria911
1970 911T w/ 2.4S
1971 911T Targa w/ 2.2
RG Member # 818
Old 01-29-2013, 07:50 PM
Taking it apart is easy
Jerome74911S's Avatar
Best,
Grady
Amen to that.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 01-30-2013, 08:04 AM
