Mike the mechanic's Avatar
How can I get more flow to my oil cooler?
Hey folks, is there any way to get more air flow thru my front fender mounted oil cooler? I have seen that little add on peice that goes in the place of your corner light, but it's just too ugly.
It seems as though there is no passage for air to flow to the cooler! is there anything that can be done?
Mike
86 Carrera t
Old 07-01-2002, 06:31 AM
Toxic
derkpitt's Avatar
Make a scoop out of sheet metal under the cooler.
Even if it just hangs down a little it should help. No, I haven't made one for myself yet.
Bruce
88 Carrera Coupe, 12 Dodge Ram Hemi,
69 Barracuda Fastback, 68 Barracuda Convertible 5spd
The only substitute for cubic inches is cubic dollar$.
Old 07-01-2002, 07:38 AM
cut a 1"X 6" notch out of the top edge of the front valance, just above the fog light. it's barely noticeable.
206 637 4071
Old 07-01-2002, 07:43 AM
The above suggestions are good for +30 mph (or so). For low vehicle speeds, stop and go driving, add a fan to the cooler. Spal makes a nice, small fan.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 07-01-2002, 10:09 AM
Thanks for the sugestions, I will try both Jw's and derkpit's but just curious, Sherwood, wouldn't the fan cause an airflow restriction at higher speeds? Sounds like good idea!
thanks guys!
Mike
86 Carrera t
Old 07-01-2002, 10:16 PM
Administrator
Jack Olsen's Avatar
I used to have a sheet metal scoop under the front bumper. This picture shows it, a little.
Old 07-01-2002, 10:56 PM
Team California
speeder's Avatar
Sherwood, Who is spal? Do you have a link? Is it cheaper than the OEM one? TIA.
Denis
Old 07-02-2002, 12:37 AM
