For that he will recommend that you buy some spray on insulation.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
Banned
And my '97 Ford F150, on regular AC, can reduce the interior of the cab to meat locker temps in minutes while towing a boat during the summer. No, it's not the system that's the problem, it's the fact that there needs to be electric fans pulling air through the condenser. What a crock of crap. Have you seen the evaporators in any garden variety Audi? They must hold three or four times the volume of working fluid as does the 911 evaporator. The truck evaporator is a gigantic thing. When I saw the size of the evaporator in the Porsche, I puzzled at how much smaller it was than any automotive evaporator I'd seen. Area matters. wwest will no doubt bring another subject change to the table here. Later on, I'll have to do a linear logic smackdown of his latest long reply to me. The red herrings and non sequiturs are breath-taking. |
Detached Member
Interesting thread. I have an ROW 84 Targa that didn't originally have A/C. What was added on by some PO, was a Seiko compressor, a deck lid condenser, a L/R wheel well condenser, an 18" by 18" under pan condenser and a factory front condenser. I converted it to R134a and put in barrier hoses, a 134a receiver/drier and 134 expansion valve. I also put in a "Jim Sims subcooler", per a thread he did on how to make one. I got OK temps (20 degree diff between inside and ambient) , but noticed that when I left the house in August to go to the store it would cool down nicely, but not cool hardly at all on the way home. I concluded, right or wrong, that the deck lid condenser was getting heat soaked in the parking lot. I removed the deck lid condenser and found that at least it stayed as poorly cooled from then on to and from the store. I also found the engine temp was a lot lower. With a Targa, and a black interior, I don't know if I can get much better.
My air velocity sucks, I'd like to get a better blower fan for the evaporator.
Hugh |
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
1. Read Keuhl's website
2. Called and talked to him 2. Bought Keuhl's stuff 3. Everything got delivered to my house exactly as he said it would 4. Mechanic installed Keuhl stuff with zero issues, missing parts, or quality defects 5. System worked exactly as advertised except I had some initial problems with condenser freezing which turned out to be improper probe placement in the evap by my mech despite the printed instructions clearly showing the right way to do it. Corrected probe placement. No problems. Even had an engine rebuild and went to turn the a/c on the Sunday after I picked the car up and it didn't work. I called Keuhl and left a message figuring I'd get a call back the next business day. He called me 10 minutes later and stayed on the line diagnosing the system and identified that they forgot to reconnect the high/low pressure cutoff. Reconnected it. System worked perfectly and saved my Sunday afternoon drive through the southern Virginia countryside. 6. System has been in 4.5 years and I have lived in NW Florida, southern Virginia, Texas and Hawaii. (military guy so I move a lot) Constant 29-35 degree vent temps. I run the variable fan about 60% of max and the temp selector about 60% of max cold. Car is my daily driver so I have 4 summers in hot places in my dark blue interior cab. Car sits in a parking lot with a sunshield in the windshield. Rear plastic window gets condensation on it becuase of the performance of the system. Wife constantly asks me to turn the fan speed down as I like it really cold. Engine temp stays below 9 o'clock regardless of OAT. 7. No freon added in the last several years. 8. Words and claims are meaningless...your customers will sell your product based on performance and customer service. 9. I could care less about fans, thermodynamics, compressors, temps, txvs, binary, trinary switches, etc. I just want my car ice cold. It is. 10. Anyone can pm me if you are interested in more info. |
Military pay must have changed a LOT since my time. Last edited by wwest; 02-07-2013 at 08:44 PM.. |
WWEST. I had a dodge neon that needed a new evap, whole dash had to come out.
Compressor was also bad. That bill was more than the Keuhl kit in my 911. Its also 1/10 what I spend on my engine rebuild and fuel systen upgrade. Its all a matter of perspective. When you live in a hot humid climate, its really not an unreasonable number. I dont think you get that... its called logic...
Banned
Kuehl needs to prove to himself, for himself, that my solution is well grounded. The problem being is that he can't do that absent denigrating the $$$ value of his own product set. So we can expect more and more of his non-factual "reasoning". |
Perhaps you should actually log in and look at all the graphs and charts Kuehl has posted here and on his site... most compare stock to every component he sells.
not sure how much more factual that you could be. Nothing is less factual than your rants... which not only usually defy logic but have often been scientifically incorrect. Quote:
After many years I have not had to add one ounce of refrigerant.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Barrier hoses vs not. What actual proof do we have, anyone of us, that the non-barrier aspect, specifically, of the OEM hoses are the base cause of refrigerant loss over such a short period. What if the problem is really poor o-ring seals or fittings prone to leakage when the high side PSI exceeds the OEM design specs? Has anyone, ANYONE, replaced ONLY the non-barrier hoses and had that, only that (NO other changes to the OEM system) solve the leakage problem? And even so, might new modern day hoses have enough sealing/coupling improvement, independent of being of the barrier design, that the leakage issue, were it caused by high side over-pressure, is resolved? Who would not agree that the only real method for disproving the validity of my solution is an actual test. Eliminate the possibility of the high side going over-pressure and thereby see, discover, if the 2 year leakage "cycle" sustains. And. How could ANYONE not agree that reducing the PEAK high side pressure, as it occurs in the pure OEM state, ~350PSI max, would reduce the leakage rate of the OEM non-barrier hoses. Anyone? |
That defies WWEST Theory.
I have had a similar experience. Have not added R134a in several seasons.
There are dozens of us who have bought Keuhl kits that have not added refrigerant in many seasons. Whether its the new sanden compressor, or the hose, is really immaterial... because AC systems are systems.. and needed to be treated as such... in my case i have a stock OEM rear deck. so if fittings where the issue, that is where it would occur. It is also where the pressure would be the highest. Also not sure the Sanden orings are any different than OEM. high pressures are high pressures. it has not occurred. so that would lead me to believe that its the hose.
you attempt to isolate independent parts and then wonder why it doesn't represent a comprehensive solution that can be duplicated.. Why dont you just change the oil and not the filter. Why dont you change the wires and not the plugs, cap and rotor, why dont you change the pistons and not the rings. why dont you change the chains and not the rails. Every mechanical system on these cars requires a systematic approach. Your arguments make no sense at all and defy all logic. Adding a couple fans and switches is not the answer to all AC woes. If you really want to prove that it is, then link up with Reid or some other idiot who thinks they are the gods of AC and prove it. It is not up to those with proven solutions to prove that yours is better. it is up to you. if you arent going to do that, then shut up already... Quote:
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. Last edited by brads911sc; 02-08-2013 at 12:33 PM.. |
Banned
Your claim that Griff hasn't given data is FALSE. Please stop making this claim. Griff need not prove anything to anyone. Your solution isn't really a solution to anything but poor system performance below 1700 RPM. And in fact, your solution might be an actual problem at higher RPM due to engine cooling air restrictions. Changing the focus back to Griff does not make this problem of yours disappear. Changing the burden of proof is also a nice red herring, but as any student of logic knows, red herring use is logical fallacy. You don't want to play the logic card here - you're overmatched. |
Tags |
air conditioner , rough idle |
